[mapserver-users] Production mapserver
Smith, Michael ERDC-CRREL-NH michael.smith at usace.army.mil
Mon Mar 21 16:32:34 EDT 2011
Jeff,
For the WMS Benchmarking effort, we used the FastCGI library from
http://www.fastcgi.com.
It is the mapserv executable that you will call via fastcgi.
We set up a separate fcgi-bin path for mapserver with fastcgi. That is not
actually required. The URL here would be
http://server/fcgi-bin/mapserv?map=XXX
Our apache setup looked like this
ScriptAlias /fcgi-bin/ "/opt/mapserver/fcgi-bin/"
<Directory /opt/mapserver/fcgi-bin/>
   SetHandler fcgid-script
   Options +ExecCGI +FollowSymLinks
   # Customize the next two directives for your requirements.
   Order allow,deny
   Allow from all
</Directory>
<IfModule fcgid_module>
  FcgidInitialEnv LD_LIBRARY_PATH
/usr/lib64:/usr/lib:/usr/local/lib:/opt/mapserver/lib:/oracle/instantclient_
11_2
  FcgidMinProcessesPerClass 0
  FcgidIdleScanInterval 1
  FcgidProcessLifeTime 10
  FcgidIOTimeout 100
</IfModule>
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
On 3/21/11 3:30 PM, "Jeff Dege" <jeff.dege at korterra.com> wrote:
> So, from what I'm hearing Apache vs. Lighttpd isn't going to make a
> significant difference.
> Cgi vs. FastCGI very definitely will.
> Great.  So how do I get FastCGI working?
> There are docs at: http://mapserver.org/optimization/fastcgi.html
> They are only getting me part of the way there.
> 1. I'm seeing two packages, that are available for Apache, mod_fastcgi and
> mod_fcgi.  Are these both needed?  Only one needed?  Are they replacements,
> alternatives, or entirely unrelated to each other?
> 2. In the Configuration section of the above doc, it says to modify http.conf
> to load the module, and to add a handler.  The Ubuntu packages placed
> fastcgi.conf and fastcgi.load in /etc/apache2/mods-available.  I expect that I
> simply need to create a link to these in /etcs/apache2/mods-enabled, the way
> the others are.
> 3. The Configuration section also says to add a FastCgiConfig command.  Where
> should this be?
> I see nothing in that configuration that indicates that it's the mapserv
> executable I want to run via fastcgi.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110321/9bfa8262/attachment-0001.html
