[mapserver-users] Too many open files...
Lee Meilleur lee.meilleur at gis.leg.mn
Mon Mar 28 17:45:55 EDT 2011
Fedora 12
Apache 2.2.14
Prefork MPM
./shp2img: error while loading shared libraries: librx.so.0: cannot open shared object file: No such file or directory (this was news to me)
Serving shapefiles only.
MapServer version 5.6.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Thanks
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
Sent: Monday, March 28, 2011 4:29 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Too many open files...
On 3/28/2011 5:05 PM, Lee Meilleur wrote:
> Hello,
> Has anyone run into the error: "Too many open files: couldn't set
> child process attributes: /var/www/cgi-bin/mapserv"? This error shows
> up in an Apache error_log. A broken image now shows up for MapServer
> layers since this started. I've tried changing the ulimits or the
> MaxRequestsPerChild for Apache with no luck. Any other ideas?
You probably need to give us more information like:
Which OS?
Which Apache version?
Which Apache MPM module are you using?
/var/www/cgi-bin/mapserv -v output?
Does this happen when you run shp2img?
What are you serving via mapserver? vectors, imagery, database, etc?
-Steve W
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
