[mapserver-users] WFS Intersect with gml:box
Joaquín Rodriguez-Guerra Urcelay jrguerra at gmv.com
Thu Mar 31 05:31:17 EDT 2011
Thank you both for your help, the filter is finally working :D
The bug is fixed, gml:box works now with intersect. I wanted to confirm this in the bug report, but I havent found they way to write anything there (is it because the bug is now closed?)
Yesterday I was not getting the results I expected because I think my connection to the mysql database had some problem. I tried with a shapefile and it was working perfectly, so I then played  a bit with the mysql connection and now it is working :)
Joaquín
________________________________________
De: Yewondwossen Assefa [yassefa at dmsolutions.ca]
Enviado el: miércoles, 30 de marzo de 2011 22:48
Para: Rahkonen Jukka
CC: mapserver-users at lists.osgeo.org; Joaquín Rodriguez-Guerra Urcelay
Asunto: Re: [mapserver-users] WFS Intersect with gml:box
On 30/03/2011 4:16 PM, Rahkonen Jukka wrote:
> Hi,
> "Intersect" means the same as "not disjoint", that the two geometries have at least one point in common. Thus WFS Intersects should select the point that is inside the "box" in the query. I made a quick test with OpenJUMP which is using JTS and it really does select such a point with a apatial query Intersects.
  Geos lib used by MapServer should  act the same as JTS I beleive.
Joaquín, you can maybe attach your simple map/data/url to the bug and I
will check it using MapServer trunk.
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
This message including any attachments may contain confidential
information, according to our Information Security Management System,
 and intended solely for a specific individual to whom they are addressed.
 Any unauthorised copy, disclosure or distribution of this message
 is strictly forbidden. If you have received this transmission in error,
 please notify the sender immediately and delete it.
Este mensaje, y en su caso, cualquier fichero anexo al mismo,
 puede contener informacion clasificada por su emisor como confidencial
 en el marco de su Sistema de Gestion de Seguridad de la
Informacion siendo para uso exclusivo del destinatario, quedando
prohibida su divulgacion copia o distribucion a terceros sin la
autorizacion expresa del remitente. Si Vd. ha recibido este mensaje
 erroneamente, se ruega lo notifique al remitente y proceda a su borrado.
Gracias por su colaboracion.
