[mapserver-users] Problems with the WMS Client VERSION 1.3.0
Iris Rittinger (Terraplan)
terraplan at gmx.net
Tue May 3 17:29:49 EDT 2011
I am trying to include a WMS Layer with the WMS Version 1.3.0 in my
MapFile. I have included serveral WMS Layers, but so far only VERSION
1.1.1 or lower. The syntax I used before does not seem to work here. I
keep on getting the error message:
msBuildWMSLayerURL(): WMS connection error. MapServer supports only WMS
1.0.0 to 1.1.1 (please verify the VERSION parameter in the connection
string)
My Mapserver Version is MapServer version 5.7-dev from FWTools2.4.7.
My Mapfile includes the following Layer:
LAYER
NAME "Deutschland"
TYPE RASTER
STATUS DEFAULT
CONNECTIONTYPE WMS
CONNECTION "http://gdz.bkg.bund.de/wms_dtk2500"
METADATA
"wms_srs" "epsg:4326"
"wms_name" "0"
"wms_title" "DTK2500"
"wms_server_version" "1.3.0"
"wms_format" "image/png"
"wms_onlineresource" "http://gdz.bkg.bund.de/wms_dtk2500"
END
END
When I include the CONNECTION in my MapFile, then I get the described
error. When I ommit the CONNECTION String and use the
wms_onlineresource which seems to be the newer syntax, then I do not get
the error message, but I can also not see the map. When I use
wms_server_version 1.1.0, then I do see the map, but on a wrong
position. From what I read that might have something to do with the
change of the axis between 1.1.0 and 1.3.0.
Did the Syntax for the mapfile change between the Version 1.1.0 and
1.3.0 and I did not see it in the documentation or am I missing
something else? Does the wms_srs still work, since in the url I need
the CRS for the projection. Any ideas?
The following REQUEST works in my browser, so the wms Server is running:
http://gdz.bkg.bund.de/wms_dtk2500?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-90,-180,90,180&CRS=EPSG:4326&WIDTH=953&HEIGHT=480&LAYERS=0&STYLES=&FORMAT=image/png&DPI=96&TRANSPARENT=true
Any help would be greatly appreciated.
Thanks,
Iris Rittinger
Iris Rittinger
Terraplan
Gewerbestr. 33
79229 Schallstadt
www.terraplan.com
