VS: [mapserver-users] Mapserver search performance
Mark Korver
mwkorver at gmail.com
Wed May 4 09:51:57 EDT 2011
I agree with Andreas,
if you just want to manipulate the shapefile and continue to use a
moded shapefile with MapServer then Spatialite ( or ogr2ogr ) can help
you, but if you want query flexibility with MapServer then postGIS is
the way to go.
On Wed, May 4, 2011 at 3:23 AM, Eichner, Andreas - SID-NLKM
<Andreas.Eichner at sid.sachsen.de> wrote:
> Hi. The first thing to note: editing a DBF with Excel & Co. seems to be
> a _really_ bad idea. Those who tried that got Shapes wired to wrong
> attribute lines. So DBF, SHP, SHX and QIX files have to be used as a
> whole or will usually end up in a corrupted dataset. I would suggest
> "ogr2ogr" from the GDAL suite. It's fast, reliable, can do joins and is
> aware of the mentioned dependencies.
> Please note that such a fileset can only provide a spatial index via a
> QIX file. This is OK if you only want to filter by BBOX. If you want to
> filter by attribute all lines of the DBF still need to be scanned. In
> such cases it's wise to use ogr2ogr to split the data in pre-filtered
> sets.
> Using a more sophisticated database like PostGIS or SpatialLite can help
> you implement more complex scenarios. Since MapServer has no native
> driver for SpatialLite it's probably not as fast as it is supposed to
> be. This mostly depends on OGRs implementation.
> Greetings
>> Is there a DBF editor out
>> there that can be used to import the fields from any external data
>> source into the shapefile attribute DBF without affecting the
>> structure? I looked for a lot but they do not have the capability of
>> doing a JOIN based on a common field and pulling data into the
>> shapefile DBF automatically.
> mapserver-users at lists.osgeo.org
