[mapserver-users] Mapfile syntax highlighting
Tamas Szekeres
szekerest at gmail.com
Wed May 4 14:44:37 EDT 2011
Thomas,
Thanks for the input, it was really helpful.
Best regards,
Tamas
2011/5/4 Thomas Gratier <osgeo.mailinglist at gmail.com>
> Hello,
> Retrieve the ZIP
> http://www.esnips.com/doc/947c00b1-9703-429d-8943-c6e1d4dd62f2/map_properties
> For Ubuntu
> wget
> unzip map_properties.zip
> sudo cp map.properties /usr/share/scite/
> sudo chmod 777 /usr/share/scite/map.properties
> sudo gedit /usr/share/scite/SciTEGlobal.properties
> #Before import matlab, add
> import map
> #Now open a mapfile in scite and you have syntax highlighting
> You can have a look on
> http://sites.google.com/site/gianpierocampanella/files
> It's for Notepad++ highlighting but Scite and Notepad++ shared Scintilla
> library behind.
> Be careful, both solutions use mapserver syntax from one, two or more
> years.
> Regards
> ThomasG
> GIS specialist
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110504/00402a7e/attachment.html
