[mapserver-users] Problems with the WMS Client VERSION 1.3.0
Iris Rittinger (Terraplan)
terraplan at gmx.net
Thu May 5 02:59:07 EDT 2011
I found the error. The letters EPSG in the srs_wms have to be
uppercase. I used the lower case letters. Now it works.
Thanks
Iris Rittinger
Am 03.05.2011 23:29, schrieb Iris Rittinger (Terraplan):
> Hi,
> I am trying to include a WMS Layer with the WMS Version 1.3.0 in my
> MapFile. I have included serveral WMS Layers, but so far only VERSION
> 1.1.1 or lower. The syntax I used before does not seem to work here.
> I keep on getting the error message:
> msBuildWMSLayerURL(): WMS connection error. MapServer supports only
> WMS 1.0.0 to 1.1.1 (please verify the VERSION parameter in the
> connection string)
> My Mapserver Version is MapServer version 5.7-dev from FWTools2.4.7.
> My Mapfile includes the following Layer:
> LAYER
> NAME "Deutschland"
> TYPE RASTER
> STATUS DEFAULT
> CONNECTIONTYPE WMS
> CONNECTION "http://gdz.bkg.bund.de/wms_dtk2500"
> METADATA
> "wms_srs" "epsg:4326"
> "wms_name" "0"
> "wms_title" "DTK2500"
> "wms_server_version" "1.3.0"
> "wms_format" "image/png"
> "wms_onlineresource" "http://gdz.bkg.bund.de/wms_dtk2500"
> END
> END
> When I include the CONNECTION in my MapFile, then I get the described
> error. When I ommit the CONNECTION String and use the
> wms_onlineresource which seems to be the newer syntax, then I do not
> get the error message, but I can also not see the map. When I use
> wms_server_version 1.1.0, then I do see the map, but on a wrong
> position. From what I read that might have something to do with the
> change of the axis between 1.1.0 and 1.3.0.
> Did the Syntax for the mapfile change between the Version 1.1.0 and
> 1.3.0 and I did not see it in the documentation or am I missing
> something else? Does the wms_srs still work, since in the url I need
> the CRS for the projection. Any ideas?
> The following REQUEST works in my browser, so the wms Server is running:
> http://gdz.bkg.bund.de/wms_dtk2500?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-90,-180,90,180&CRS=EPSG:4326&WIDTH=953&HEIGHT=480&LAYERS=0&STYLES=&FORMAT=image/png&DPI=96&TRANSPARENT=true
> Any help would be greatly appreciated.
> Thanks,
> Iris Rittinger
Iris Rittinger
Terraplan
Gewerbestr. 33
79229 Schallstadt
www.terraplan.com
