[mapserver-users] Why is LAYERS parameter required in
GetFeatureInfo
Bart van den Eijnden
bartvde at osgis.nl
Thu May 5 05:59:46 EDT 2011
The WMS spec does say it is required:
7.3.3.4 map_request_copy
<map request copy> is not a name/value pair like the other parameters. Instead, most of the GetMap request parameters that generated the original map are repeated. Two are omitted because GetFeatureInfo provides its own values: VERSION and REQUEST. The remainder of the GetMap request shall be embedded contiguously in the GetFeatureInfo request.
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On May 5, 2011, at 11:57 AM, Ivan Mincik wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi,
> I would like to ask, why is the LAYERS parameter required in
> Looking to WMS specification, it is not mentioned in this type of
> request. Neither in Mapserver doc I can't find any relevant info.
> Tested on Mapserver 5.6.6. Without LAYERS parameter I get:
> msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the
> LAYERS parameter.
> Thanks
> Ivan Mincik, Gista s.r.o.
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAk3CdIsACgkQVqso/9cUsCydZgCgzE3uoIfl3AknEvoVEEuxgHFU
> 1twAniaRmixQ200mbLDlcJe3367RWIgo
> =Xy55
> -----END PGP SIGNATURE-----
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110505/6ecece89/attachment.html
