[mapserver-users] Template for itemquery - GeoMoose
Stephen Knox stephenknox73 at gmail.com
Thu May 5 16:12:49 EDT 2011
Hi Mapserver List!
I'm wondering if any of you can help me with a problem I'm having with
GeoMoose, using Mapserver. I am using the latest version of Geomoose
(2.4RC1) and Mapserver 5.6.3 (packaged for Fedora 14).
My issue is when I carry out a query in Geomoose. I have set everything
there up according to the docs, and submitted info to the mailing list, so
hopefully it's all correct. From what I can gather, the problem is when the
php script calls:
$queryLayer->queryByRect($queryLayer->getExtent());
In the Apache log, this returns
msPostGISLayerResultsGetShape: Assertion `layer->layerinfo != ((void *)0)'
failed.
and the mapserver log says:
getSymbol(): Symbol definition error. Parsing error near (per_ttw_lu):(line
320) [per_ttw_lu is the name of my field. It is definitely there as I use it
in an identify query, and I can map the Mapserver layer fine]
I'm convinced this is something to do with the template - GeoMoose does
something non-standard with Mapserver templates, and the template is
specified in the METADATA for the layer. But, from the debugging I've done
in PHP, the template seems to be properly specified - it is specified using
itemquery itemquery_template.html in the METADATA tag. I'm not sure I've got
the right markup in the template though - currently it is:
<!-- MapServer Template -->
<tr bgcolor="#DEE5EB">
[errmsg]
<tr/>
<tr>
<td colspan="2"><b><u>Output Areas</u></b></tr>
<tr>
<td align="right"><b>Census Code:</b></td>
<td>[census_code]</td>
</tr>
<tr>
<td align="right"><b>Percentage travel by LU:</b></td>
<td>[per_ttw_lu]</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
Can anyone help me with this, or help me to debug it better.
Thanks
Steve
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110505/59802434/attachment.html
