[mapserver-users] Arrowhead in Mapserver 6.0
thomas bonfort
thomas.bonfort at gmail.com
Fri May 6 04:58:51 EDT 2011
vector symbols are ill-defined by nature in mapserver, especially if
you are using negative values and single points like you are.
more precisely, you should *never* use
-99 -99
x y
-99 -99
as in that case you are drawing a line with a single point which will
be rightfully discarded by cairo and agg, whereas gd will render a
single pixel.
A vector symbol that should work should be
POINTS
0 0
1 0.5
0 1
END
But I would strongly recommend that you use a truetype symbol for arrowheads:
SYMBOL
TYPE TRUETYPE
FONT sans
CHARACTER '>'
NAME "to"
END
SYMBOL
TYPE TRUETYPE
FONT sans
CHARACTER '<'
NAME "from"
END
regards,
thomas
On Fri, May 6, 2011 at 06:59, Makoto Niwa <niwa at orkney.co.jp> wrote:
> Hi,list
> I tried new MapServer 6.0(rc2).
> I got diffrent images GD/PNG and CAIRO renderes for arrowhead symbols.
> Attached images are
> ms6_gd.gif : render by GD/GIF
> ms6_aggpng8.png : render by AGG/PNG
> CAIRO renderer image is as same as AGG.
> CARIO/AGG renderer has incorrect ofsset for arrowhead symbols.
> I used vcetor type symbols for arrowhead symbols.
> But I got same results both AGG and GD in MapSever 5.6
> Is this behavior correct in MapServer 6 ?
> regards,
> makoto.
> Symbol definition:
> SYMBOL
> NAME "from"
> TYPE vector
> POINTS
> 0 10
> -20 0
> 0 -10
> -99 -99
> -40 10
> -99 -99
> -40 -10
> END
> END
> SYMBOL
> NAME "to"
> TYPE vector
> POINTS
> 0 10
> 20 0
> 0 -10
> -99 -99
> 40 10
> -99 -99
> 40 -10
> END
> END
> Style in the layer:
> STYLE
> ANGLE AUTO
> GEOMTRANSFORM "start"
> SYMBOL "from"
> COLOR 255 20 20
> WIDTH 2
> END
> STYLE
> ANGLE AUTO
> GEOMTRANSFORM "end"
> SYMBOL "to"
> COLOR 20 20 255
> WIDTH 2
> END
> Makoto Niwa Orkney,Inc.
> Queen's Tower C 12F
> 2-3-5 Minatomirai, Nishi, Yokohama, Japan
> TEL.81-45-228-3320 FAX.81-45-228-3321
> E-mail niwa at orkney.co.jp http://www.orkney.co.jp
> mapserver-users at lists.osgeo.org
