[mapserver-users] WFS with 6.0.0 Beta RC2
Arnd Wippermann
arnd.wippermann at web.de
Mon May 9 16:44:02 EDT 2011
I'm trying to get WFS working with 6.0.0 Beta RC2.
If i use MapServer 5.6.5 a wfs post request returns the features.
If I use MapServer 6.0.0 the same post request responses with
...<gml:null>missing</gml:null>.
The BBOX coordinates, the mapfile projection and layer is in EPSG:3763.
In the WEB METADATA Block is set 'wfs_srs' 'EPSG:3763'
There is no reprojection needed.
Is there something I have to consider, when using MapServer Version 6.0.0
and WFS.
Arnd
POST
<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
version="1.0.0" maxFeatures="100">
<wfs:Query typeName="default">
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
<ogc:BBOX>
<ogc:PropertyName>msgeometry</ogc:PropertyName>
<gml:Box xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:3763">
<gml:coordinates decimal="." cs="," ts=" ">-535786.68671593,-509560.89777426
559489.72019154,364218.61581997</gml:coordinates>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
RESPONSE MapServer 5.6.5
<?xml version='1.0' encoding="ISO-8859-1" ?>
<wfs:FeatureCollection
xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
http://dir/mapserv.exe?map=mapfile&Service=WFS&SERVICE=WFS&VERSI
ON=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=default&OUTPUTFORM
AT=XMLSCHEMA">
<gml:boundedBy>
<gml:Box srsName="EPSG:3763">
<gml:coordinates>-21537.507741,-91486.277029
44944.469424,-56235.046915</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<ms:default>
<gml:boundedBy>
<gml:coordinates>-21441.941044,-67958.139907
-11234.384166,-56235.046915</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<ms:msGeometry>
<gml:Polygon srsName="EPSG:3763">
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates>-21441.941044,-56235.046915
-11234.384166,-56256.314719 -16838.013555,-67958.139907
-21441.941044,-56235.046915 </gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</ms:msGeometry>
<ms:name>No 1</ms:name>
<ms:descriptio>AREA</ms:descriptio>
</ms:default>
</gml:featureMember>
RESPONSE MapServer 6.0.0
AT=XMLSCHEMA">
<gml:boundedBy>
</gml:boundedBy>
</wfs:FeatureCollection>
LOG Entry
[Mon May 09 22:11:54 2011].666000 CGI Request 1 on process 3968
[Mon May 09 22:11:54 2011].666000 msQueryByFilter(): Search returned no
results. No matching record(s) found.
[Mon May 09 22:11:54 2011].713000 msProjectRect(): some points failed to
reproject, doing internal sampling.
[Mon May 09 22:11:54 2011].713000 mapserv request processing time (msLoadMap
not incl.): 0.047s
[Mon May 09 22:11:54 2011].713000 msFreeMap(): freeing map at 0184A9E8.
