[mapserver-users] Rendering Challenges
Brent Fraser
bfraser at geoanalytic.com
Tue May 10 10:21:31 EDT 2011
Thomas,
Interesting. I suspect all the polygons are digitized the same was as
I think this is a requirement for shapefiles. The result of using:
STYLE
OUTLINECOLOR 255 211 127
OFFSET 1.5 -99
WIDTH 3
END
results in http://i54.tinypic.com/25a22k4.jpg Close, but notice the
"bleed" outside the polygon at the sharp corners.
Thanks!
Best Regards,
Brent Fraser
On 5/10/2011 1:38 AM, thomas bonfort wrote:
> Brent,
> those are interesting questions
> On Mon, May 9, 2011 at 21:51, Brent Fraser<bfraser at geoanalytic.com> wrote:
>> While testing v6, I can up with the following list of things I couldn't do
>> (see http://i56.tinypic.com/8vvprn.png for a graphic):
>> 1. Render lines inside polygon boundary (with or without opacity)
> Along with Steve's buffer proposition, you can already more or less do
> that with OFFSET , except you don't have the notion of inside/outside,
> but left/right. If all your polygons are digitized in the same
> direction (i.e. clockwise or anticlockwise) this can be done with:
> STYLE
> #FILL
> END
> STYLE
> OUTLINECOLOR r g b
> OFFSET 1.5 -99
> WIDTH 3
> OPACITY 50
> END
>> 2. Place polygon annotation on/inside boundary line
>> (http://trac.osgeo.org/mapserver/ticket/1592 point 8.)
> not possible in a single step, but by using the polygon layer a second
> time in a TYPE LINE layer for labelling should get you close.
>> 3. Rotate anno if required to fit inside a polygon
> would be a nice addition, ANGLE AUTO for polygon labels. We should
> probably give some way to define if the label should always follow the
> longest polygon diagonal, or if it should be first placed horizontally
> and fall back to automatic angling only if the horizontal one does not
> fit.
>> 4. Place polygon annotation outside polygon if anno doesn't fit inside
> The fine tuning on how to place the label text compared to the feature
> would require new mapfile keywords, but that would seem possible to
> implement. I'm not sure these kind of automatic adjustments would
> really enhance the rendered quality though.
>> 5. Place line anno above (or below) when using ANGLE FOLLOW
> This is something I would like to add to. There's a paper detailing
> the underlying algorithm here:
> http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.24.6970
>> 6. Rotate vector symbols to follow lines (a font might work but is a pain to
>> create)
> how is this different than what we already have with a negative GAP?
> On a side note, vector symbols are currently rather ill-defined in
> mapserver and would need to be tightened up before being able to use
> them for precise symbol placement like here.
>> 7. User specified character spacing
> SIZE AUTO for labels in polygon layers would be a nice addition. We'd
> have to be able to define how the size of the font varies in
> accordance with the spacing that is applied between characters.
> Before going down that road, we shall have to implement the
> refactoring proposed in http://trac.osgeo.org/mapserver/ticket/3611 so
> as not to clutter the glyph rendering functions of each renderer.
>> 8. Erase lines (but not other objects) under annotation
> This seems rather involved. It would be difficult to keep the ordering
> of layers, as the modified feature could only be drawn during the
> labelcache phase, i.e. after all other features in the map.
>> My goal was to use the published shp files
>> (http://ftp2.cits.rncan.gc.ca/pub/canvec/50k_shp/092/h/canvec_092h06_shp.zip)
>> without modification and see how close I could get to the published PDF
>> (http://ftp2.cits.rncan.gc.ca/pub/cantopo/50k_geopdf/092/h/cantopo_092h06_geopdf.zip).
>> Any suggested rendering techniques are appreciated. I'll file tickets for
>> those problems deemed worthy.
> So, most of these enhancements seem possible, some were already on my
> laundry-list of rendering enhancements I'd like to tackle. Creating
> enhancement tickets for those features is a first step, and funding
> them is the second ;)
> regards,
> thomas
>> Best Regards,
>> Brent Fraser
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
