[mapserver-users] Layer rendering performance problem
Stephen Woodbridge woodbri at swoodbridge.com
Wed May 11 11:53:34 EDT 2011
look at the mapserver utilities:
shptree myshapefile
This creates a spatial index (*.qix) and you should create one for every
shapefile you are using.
On Linux this will do the trick:
find /path/data -name \*.shp -exec shptree {} \;
If the .qix file is missing on every draw mapserver must create one on
the fly in memory and the it throws it away.
-Steve W
On 5/11/2011 11:47 AM, Jon-Paul Dobson wrote:
> Hi Jukka,
> Thanks for getting back to me so quickly. No I haven't tried this. How
> is this done and what is the benefit? Aren't Shape files already indexed?
> Regards,
> Jon-Paul.
> On Wed, May 11, 2011 at 4:41 PM, Rahkonen Jukka
> <Jukka.Rahkonen at mmmtike.fi <mailto:Jukka.Rahkonen at mmmtike.fi>> wrote:
>     Hi,
>     No answers but a question back. Have you created spatial index
>     (.qix) for your shapefiles with shptree?
>     -Jukka Rahkonen-
>      > Hi,
>      > Whenever I display a layer based on a Shape file I notice that
>     the Shape
>     file is accessed constantly. This makes rendering extremely slow when
>     compared to, for example, ESRI ArcIMS which appears to cache the
>     Shape file.
>     Is there an equivalent caching mechanism for Map Server? ArcIMS seems to
>     render an order of magnitude faster when the number of symbols runs
>     into the
>     1000s
>      > Similarly, whenever I display layer symbols using a truetype font
>     I notice
>     that the .ttf file is accessed for every symbol. This makes rendering
>     appallingly slow. Is there also any caching mechanism to prevent this?
>      > Any insight anyone can give would be much appreciated.
>     Best regards,
>     Jon-Paul.
> mapserver-users at lists.osgeo.org
