[mapserver-users] opacity and outputformat
thomas bonfort
thomas.bonfort at gmail.com
Thu May 12 03:41:05 EDT 2011
Opacity is set as a single integer between 0 and 100 on the layer level.
There are no limitations on setting it on multiple layers, but in that
case the opacity adds up, so if you have two layers with opacity 50,
the final opacity of the image ends up being 75.
If your final images end up with no opacity, this could be because
your are also including a layer with full opacity, or because you are
using a format which does not support an alpha channel (i.e. jpeg)
regards,
thomas
On Mon, May 9, 2011 at 19:18, Marc-André Trottier
<trottier.marcandre at gmail.com> wrote:
> hi!
> how can i get a output with opacity on 2 or more layers.
> with only 1 layer it's working fine but not with 2 or more.
> How should be written OPACITY when using IMAGEMODE RGBA ? (ALPHA)
> i tried something like OPACITY 22,22,22,22 but looks bad
> in all my tests, all i got was my 2 layers with full opacity (100) ...
> here is my mapfile :
> MAP
> EXTENT -8146324.306063 5632144.09953312 -8137075.425642 5638229.88815488
> FONTSET "fonts"
> IMAGECOLOR 255 255 255
> IMAGETYPE AGGA
> SIZE 732 482
> STATUS ON
> UNITS METERS
> NAME "MS"
> OUTPUTFORMAT
> NAME 'AGGA'
> DRIVER AGG/PNG
> IMAGEMODE RGBA
> TRANSPARENT TRUE
> END
> PROJECTION
> "init=epsg:900913"
> END
> LEGEND
> KEYSIZE 20 10
> KEYSPACING 5 5
> LABEL
> ANGLE 0.000000
> ANTIALIAS TRUE
> FONT "arial"
> MAXSIZE 256
> MINSIZE 4
> SIZE 10
> TYPE TRUETYPE
> BUFFER 0
> COLOR 255 255 255
> FORCE FALSE
> MINDISTANCE -1
> MINFEATURESIZE -1
> OFFSET 0 0
> PARTIALS TRUE
> END
> OUTLINECOLOR 0 0 0
> POSITION LR
> POSTLABELCACHE TRUE
> STATUS EMBED
> TRANSPARENT FALSE
> END
> QUERYMAP
> COLOR 255 255 0
> SIZE -1 -1
> STATUS OFF
> STYLE HILITE
> END
> SCALEBAR
> ALIGN CENTER
> COLOR 0 0 0
> INTERVALS 4
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> BUFFER 0
> COLOR 0 0 0
> FORCE FALSE
> MINDISTANCE -1
> MINFEATURESIZE -1
> OFFSET 0 0
> PARTIALS TRUE
> POSITION CR
> END
> OUTLINECOLOR 0 0 0
> POSITION LL
> SIZE 200 3
> STATUS EMBED
> STYLE 0
> UNITS METERS
> END
> WEB
> IMAGEPATH "path"
> IMAGEURL ""
> QUERYFORMAT text/html
> LEGENDFORMAT text/html
> BROWSEFORMAT text/html
> END
> LAYER
> CONNECTION "PATATE3"
> CONNECTIONTYPE WMS
> DEBUG 5
> METADATA
> "wms_srs" "EPSG:900913"
> "wms_name" "PATATE3"
> "wms_format" "image/png"
> "wms_server_version" "1.1.1"
> END
> NAME "Carte"
> PROCESSING "CLOSE_CONNECTION=NORMAL"
> PROJECTION
> "init=epsg:900913"
> END
> STATUS ON
> TRANSFORM FALSE
> TYPE RASTER
> UNITS METERS
> END
> LAYER
> CONNECTION "PATATE2"
> CONNECTIONTYPE WMS
> DEBUG 5
> METADATA
> "opacity" "100"
> "wms_name" "PATATE2"
> END
> NAME "PATATE2"
> PROJECTION
> "init=epsg:900913"
> END
> STATUS ON
> TRANSFORM FALSE
> TYPE RASTER
> UNITS METERS
> END
> LAYER
> CONNECTION "PATATE"
> CONNECTIONTYPE WMS
> DEBUG 5
> METADATA
> "opacity" "40"
> "wms_name" "PATATE"
> END
> NAME "PATATE"
> PROJECTION
> "init=epsg:900913"
> END
> STATUS ON
> OPACITY 40
> TYPE RASTER
> UNITS METERS
> END
> END
> mapserver-users at lists.osgeo.org
