[mapserver-users] Re: mapserver-users Digest, Vol 40, Issue 29
Ben Madin
lists at remoteinformation.com.au
Thu May 12 11:33:14 EDT 2011
Thanks Jeff,
Truth be told, I haven't set up a map file with a shapefile for about three years (all our data is in PostGIS now), so I haven't looked at the docs on that for a while.
Based on the feedback here, could I maybe suggest that the last part of the shptree page be reworded to something like
Mapfile Notes
The qix will be used when it is available and may provide significant gains in rendering speed.
ESRI index files (.sbn / .shx) are not used by MapServer.
Note Prior to Mapserver 5.2, in order for MapServer to use the.qix extension you MUST NOT specify the extension, for example:
LAYER
DATA "us_states" #MapServer will search for us_states.qix and will use it
END
LAYER
DATA "us_states.shp" #MapServer will search for us_states.shp.qix and won't find it
END
Shapefiles are native to MapServer, and therefore do not require the .shp extension in the DATA path of the LAYER.
cheers
Ben
On 13/05/2011, at 9:30 AM, mapserver-users-request at lists.osgeo.org wrote:
> From: Jeff McKenna <jmckenna at gatewaygeomatics.com>
> Date: 12 May 2011 8:58:00 PM AWST
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Layer rendering performance problem
> On 11-05-11 9:59 PM, Ben Madin wrote:
>> I'm not sure whether it is still the case, but it used also to be that
>> if you wanted to use the index, you need to name the shapefile without
>> the .shp extension. If you used the .shp extension it wouldn't use the
>> .qix index.
>> So maybe this is a question - Is that still the case?
> Hi Ben,
> This is documented at: http://www.mapserver.org/utilities/shptree.html#mapfile-notes
> "Note: As of MapServer 5.2 the qix will be used even when the .shp extension is specified"
> PS. this is why I always push the documentation team/developers to record the version number the change applies to, directly in the document.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110512/09ac7bf2/attachment.html
