[mapserver-users] RE: Rendering Challenges - GEOMTRANSFORM
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Fri May 13 10:19:53 EDT 2011
All,
Ok, now you got me thinking (again) on the ideas (some old threads) related to labeling a view. Things like overlay grids, and such. But if I understand what has just been built, couldn't some sort of sudo geometries that represent a view (BBOX for example) be used to label a view and constructs within it? View (BBOX) edge label/stylings and such, maybe starting with simpler alignment/justifications for edge labeling of a map view? Using these feature labeling options via CGI introduce all sorts of ideas about how to use these capabilities for end user "view" labeling/styling, that may be separate from the mapping data.
bobb
>>> "Lime, Steve D (DNR)" <steve.lime at state.mn.us> wrote:
Cool. I committed that patch in trunk in what will be 6.2 if folks are interested. I'll add a few other functions too (see ticket #3871).
Regarding other uses, sure it's possible. We'd need to add the GEOMTRANSFORM processing to labels and execute it before computing a label point.
I've also thought about defining a layer-level GEOMTRANSFORM that would alter the original geometry before any processing so all classes and styles would be affected and you could query it. ;-)
Your last idea (8) is a bit different. Here's you're talking about a drawing effect so we're back into styles, but in this case a label's style. Issue here is that a label has two geometries - the point, and the bbox(es) so which are you referencing with [shape]? I'm thinking that in this context we'd always mean the bbox(es) so you could create a buffered convex hull easily and draw it under a label.
Probably should create a couple of tickets...
Steve
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Thursday, May 12, 2011 10:08 AM
To: Lime, Steve D (DNR)
Cc: mapserver-users at lists.osgeo.org
Subject: Rendering Challenges - GEOMTRANSFORM
Steve,
Thanks to your patch I was able to render thick lines inside polygons
(http://i56.tinypic.com/1z347yq.jpg).
The solution of using a STYLE with GEOMTRANSFORM got me thinking of
using the technique to solve some of the labeling challenges:
2. Place polygon annotation on/inside boundary line
(http://trac.osgeo.org/mapserver/ticket/1592 point 8.)
- label the line geometry resulting from GEOMTRANSFORM
(buffer([shape], -3)) of the original polygon
5. Place line anno above (or below) when using ANGLE FOLLOW
(buffer([shape], 5)) of the original line
Currently the LABEL object uses the original geometry. Do you think it
would be possible to [optionally?] use the GEOMTRANSFORMed geometry?
Similarly, would it be possible to have the LABEL's convex hull (or a
buffer the character boxes?) used as a clipping polygons of the layer's
geometry to address:
8. Erase layer's geometry (but not other layers) under label
- possible syntax: GEOMTRANSFORM ( clip( [labelpoly] ) )
Your thoughts?
Best Regards,
Brent Fraser
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110513/9f445c53/attachment-0001.html
