[mapserver-users] Problem rendering multiple layers
thomas bonfort
thomas.bonfort at gmail.com
Fri May 13 13:22:56 EDT 2011
mixing the mode=map with a WMS request might be treated differently in
5.0 than 5.6. To be on the safe side, either do a mapserver style
mode=map request without the SERVICE and REQUEST params, or do some
pure wms requests without the mode=map (the second option seems to be
what you are trying to achieve)
i.e.: try
http://10.10.10.105/cgi-bin/mapserv?map=mapdata/ccc.map&LAYERS=county,water&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fpng&SRS=EPSG%3A4326&BBOX=-122.41859552788569,37.48140447211431,-121.56140447211433,38.33859552788568&WIDTH=450&HEIGHT=
thomas
On Fri, May 13, 2011 at 19:16, Mark K. Zanfardino <mzanfardino at gmail.com> wrote:
> I have created a simple map with two layers with shapefiles as the
> datasource. I have two servers I am using for testing in order to attempt to
> identify the source of a problem I am having when I attempt to render the
> two layers.
> Server A is running Ubuntu 9.04. It has been patched to the latest releases.
> I did *not* add the UbuntuGIS repo. I installed the package cgi-mapserver
> and mapserver-bin (along with the appropriate dependencies). MapServer
> version 5.0.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG
> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I then render my map from my browser (Firefox 3.6.17 and Chrome 11.0.696.65)
> with the following URL:
> http://10.10.10.86/cgi-bin/mapserv?mode=map&map=mapdata/ccc.map&LAYERS=county,water&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fpng&SRS=EPSG%3A4326&BBOX=-122.41859552788569,37.48140447211431,-121.56140447211433,38.33859552788568&WIDTH=450&HEIGHT=450
> <http://10.10.10.86/cgi-bin/mapserv?mode=map&map=mapdata/ccc.map&LAYERS=county,water&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fpng&SRS=EPSG%3A4326&BBOX=-122.41859552788569,37.48140447211431,-121.56140447211433,38.33859552788568&WIDTH=450&HEIGHT=450>
> The resulting image is rendered at 450x450 and displays both the county and
> water layers as expected.
> Server B is running Ubuntu 10.04. It has been patched to the latest
> releases. I *did* add the UbuntuGIS repo. I installed the same packages.
> MapServer version 5.6.6 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> I then render my map from the browser as before with the following URL:
> http://10.10.10.105/cgi-bin/mapserv?mode=map&map=mapdata/ccc.map&LAYERS=county,water&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fpng&SRS=EPSG%3A4326&BBOX=-122.41859552788569,37.48140447211431,-121.56140447211433,38.33859552788568&WIDTH=450&HEIGHT=450
> <http://10.10.10.105/cgi-bin/mapserv?mode=map&map=mapdata/ccc.map&LAYERS=county,water&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fpng&SRS=EPSG%3A4326&BBOX=-122.41859552788569,37.48140447211431,-121.56140447211433,38.33859552788568&WIDTH=450&HEIGHT=450>
> The resulting image is rendered at 740x400 and is a single white image (no
> layers rendered).
> If I only include one layer at a time the specified layer *does* render
> (again at 740x400 *not* 450x450 as specified in the URL). If I change the
> parameters &LAYERS to &LAYER (singular) and use two (one for county and one
> for water) the two layers render, again at the wrong resolution.
> I'm completely stumped. I've been using mapserver for a number of years now,
> but I hadn't upgraded to 5.6.6 as I'd been using it on my ubuntu 9.04
> server. I'd love to take advantage of the changes available in 5.6.6 but
> right now I can't seem to get any of my maps to work. Help!
> I have enabled debugging for both servers. The output for Server A when
> requesting to render both county and water is:
> [Fri May 13 10:13:21 2011].721463 msSearchDiskTree(): Search returned no
> results. Unable to open spatial index for
> /usr/lib/cgi-bin/mapdata/./ccc_gis.county.qix. In most cases you can safely
> ignore this message, otherwise check file names and permissions.
> [Fri May 13 10:13:21 2011].723899 msDrawMap(): Layer 0 (county), 0.003s
> [Fri May 13 10:13:21 2011].724028 msSearchDiskTree(): Search returned no
> /usr/lib/cgi-bin/mapdata/./ccc_gis.water.qix. In most cases you can safely
> [Fri May 13 10:13:21 2011].726447 msDrawMap(): Layer 1 (water), 0.003s
> The output for Server B is:
> [Fri May 13 10:12:23 2011].707688 msSearchDiskTree(): Search returned no
> [Fri May 13 10:12:23 2011].710121 msDrawMap(): Layer 0 (county), 0.003s
> [Fri May 13 10:12:23 2011].710285 msSearchDiskTree(): Search returned no
> [Fri May 13 10:12:23 2011].712486 msDrawMap(): Layer 1 (water), 0.002s
> My map file is as follows:
> # Start of map file
> MAP
> NAME ccc
> STATUS on
> EXTENT -122.40 37.70 -121.50 38.05
> SIZE 740 400
> UNITS dd
> SHAPEPATH "."
> IMAGECOLOR 255 255 255
> FONTSET "./fonts.list"
> TEMPLATEPATTERN "example"
> CONFIG "MS_ERRORFILE" "/var/log/mapserver.log"
> OUTPUTFORMAT
> NAME png
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE PC256
> EXTENSION "png"
> END
> OUTPUTFORMAT
> NAME png24
> DRIVER "GD/PNG"
> IMAGEMODE RGB
> EXTENSION "png"
> END
> OUTPUTFORMAT
> NAME jpeg
> DRIVER "GD/JPEG"
> MIMETYPE "image/jpeg"
> FORMATOPTION "QUALITY=75"
> IMAGEMODE RGB
> EXTENSION "jpg"
> END
> # Projection definition, consult the PROJ.4 documentation for parameter
> discussion
> PROJECTION
> "init=epsg:4326"
> END
> # Start of web interface definition (including WMS enabling metadata)
> WEB
> IMAGEPATH '/data/tmp/'
> IMAGEURL '/tmp/'
> METADATA
> WMS_TITLE "Contra Costa County Mapserver"
> WMS_ABSTRACT "This is a UMN MapServer application for Contra Costa
> County."
> # change this value to match your setup
> WMS_ONLINERESOURCE "http://localhost/cgi-bin/mapserv?"
> WMS_SRS "EPSG:4326"
> END
> END
> # Start of LAYER DEFINITIONS ---------------------------------------------
> LAYER
> NAME county
> DEBUG 3
> DATA ccc_gis.county.shp
> STATUS OFF
> TYPE POLYGON
> METADATA
> WMS_TITLE "Contra Costa County"
> WMS_ABSTRACT "County polygon for Contra Costa County."
> WMS_SRS "EPSG:4326"
> END
> CLASS
> STYLE
> OUTLINECOLOR 0 0 0
> COLOR 242 239 233
> END
> END
> END # County polygon layer ends here
> LAYER
> NAME water
> DEBUG 3
> DATA ccc_gis.water.shp
> STATUS OFF
> TYPE POLYGON
> METADATA
> WMS_SRS "EPSG:4326"
> END
> CLASS
> STYLE
> COLOR 155 177 205
> END
> END
> END # Water polygon layer ends here
> END
> mapserver-users at lists.osgeo.org
