[mapserver-users] opacity and outputformat
Marc-André Trottier
trottier.marcandre at gmail.com
Fri May 20 13:30:28 EDT 2011
url = "blablabl/cgi-wms/mapserv?map=patate&randomnumber" + mt_rand() + "&";
layer->set("connection",url)
and everything is good
2011/5/19 Marc-André Trottier <trottier.marcandre at gmail.com>
> i'm using MapScript to create un mapObj.
> finally a draw the image with Map->draw();
> but the OPACITY is not good. Just one OPACITY, of my two layers, is set to
> all image
> i got this for my Outputformat :
> OUTPUTFORMAT
> NAME "aggpng24"
> MIMETYPE "image/png; mode=24bit"
> DRIVER "AGG/PNG"
> EXTENSION "png"
> IMAGEMODE "RGBA"
> TRANSPARENT TRUE
> END
> i think it's good.
> if the address is not the same in the parameter CONNECTION
> it's all good.
> can i add a random number in my CONNECTION ?
> with the mapscript
> Marc-André Trottier
> 2011/5/12 thomas bonfort <thomas.bonfort at gmail.com>
> Opacity is set as a single integer between 0 and 100 on the layer level.
> There are no limitations on setting it on multiple layers, but in that
> case the opacity adds up, so if you have two layers with opacity 50,
> the final opacity of the image ends up being 75.
> If your final images end up with no opacity, this could be because
> your are also including a layer with full opacity, or because you are
> using a format which does not support an alpha channel (i.e. jpeg)
> regards,
> thomas
> On Mon, May 9, 2011 at 19:18, Marc-André Trottier
> <trottier.marcandre at gmail.com> wrote:
> > hi!
> > how can i get a output with opacity on 2 or more layers.
> > with only 1 layer it's working fine but not with 2 or more.
> > How should be written OPACITY when using IMAGEMODE RGBA ? (ALPHA)
> > i tried something like OPACITY 22,22,22,22 but looks bad
> > in all my tests, all i got was my 2 layers with full opacity (100) ...
> > here is my mapfile :
> > MAP
> > EXTENT -8146324.306063 5632144.09953312 -8137075.425642
> 5638229.88815488
> > FONTSET "fonts"
> > IMAGECOLOR 255 255 255
> > IMAGETYPE AGGA
> > SIZE 732 482
> > STATUS ON
> > UNITS METERS
> > NAME "MS"
> > OUTPUTFORMAT
> > NAME 'AGGA'
> > DRIVER AGG/PNG
> > IMAGEMODE RGBA
> > TRANSPARENT TRUE
> > END
> > PROJECTION
> > "init=epsg:900913"
> > END
> > LEGEND
> > KEYSIZE 20 10
> > KEYSPACING 5 5
> > LABEL
> > ANGLE 0.000000
> > ANTIALIAS TRUE
> > FONT "arial"
> > MAXSIZE 256
> > MINSIZE 4
> > SIZE 10
> > TYPE TRUETYPE
> > BUFFER 0
> > COLOR 255 255 255
> > FORCE FALSE
> > MINDISTANCE -1
> > MINFEATURESIZE -1
> > OFFSET 0 0
> > PARTIALS TRUE
> > END
> > OUTLINECOLOR 0 0 0
> > POSITION LR
> > POSTLABELCACHE TRUE
> > STATUS EMBED
> > TRANSPARENT FALSE
> > END
> > QUERYMAP
> > COLOR 255 255 0
> > SIZE -1 -1
> > STATUS OFF
> > STYLE HILITE
> > END
> > SCALEBAR
> > ALIGN CENTER
> > COLOR 0 0 0
> > INTERVALS 4
> > LABEL
> > SIZE MEDIUM
> > TYPE BITMAP
> > BUFFER 0
> > COLOR 0 0 0
> > FORCE FALSE
> > MINDISTANCE -1
> > MINFEATURESIZE -1
> > OFFSET 0 0
> > PARTIALS TRUE
> > POSITION CR
> > END
> > OUTLINECOLOR 0 0 0
> > POSITION LL
> > SIZE 200 3
> > STATUS EMBED
> > STYLE 0
> > UNITS METERS
> > END
> > WEB
> > IMAGEPATH "path"
> > IMAGEURL ""
> > QUERYFORMAT text/html
> > LEGENDFORMAT text/html
> > BROWSEFORMAT text/html
> > END
> > LAYER
> > CONNECTION "PATATE3"
> > CONNECTIONTYPE WMS
> > DEBUG 5
> > METADATA
> > "wms_srs" "EPSG:900913"
> > "wms_name" "PATATE3"
> > "wms_format" "image/png"
> > "wms_server_version" "1.1.1"
> > END
> > NAME "Carte"
> > PROCESSING "CLOSE_CONNECTION=NORMAL"
> > PROJECTION
> > "init=epsg:900913"
> > END
> > STATUS ON
> > TRANSFORM FALSE
> > TYPE RASTER
> > UNITS METERS
> > END
> > LAYER
> > CONNECTION "PATATE2"
> > CONNECTIONTYPE WMS
> > DEBUG 5
> > METADATA
> > "opacity" "100"
> > "wms_name" "PATATE2"
> > END
> > NAME "PATATE2"
> > PROJECTION
> > "init=epsg:900913"
> > END
> > STATUS ON
> > TRANSFORM FALSE
> > TYPE RASTER
> > UNITS METERS
> > END
> > LAYER
> > CONNECTION "PATATE"
> > CONNECTIONTYPE WMS
> > DEBUG 5
> > METADATA
> > "opacity" "40"
> > "wms_name" "PATATE"
> > END
> > NAME "PATATE"
> > PROJECTION
> > "init=epsg:900913"
> > END
> > STATUS ON
> > OPACITY 40
> > TYPE RASTER
> > UNITS METERS
> > END
> > END
> > ______________________________
>> _________________
>> > mapserver-users mailing list
>> > mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110520/c23b8cb9/attachment.html
