[mapserver-users] MS4W Crash: Faulting app: mapserv.exe, module:
libmap.dll
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Nov 7 08:50:33 EST 2011
On 11-11-07 9:46 AM, Michael Shishcu wrote:
> Hi,
> I had the similar issue long time ago with v5.2 that was caused by some
> features being actually not simple polygons but lines/complex polygons
> with arcs.
> I am not sure if this can be the issue you've got, anyway, if everything
> else (memory, libs, etc.) seems to be ok, make sure the data is "well".
> regards, michael
I have the same thoughts as Michael: the 'test' case provided is massive
- cut it down to one small layer, for a snippet of the data (in KB
size), don't use classes/labels/fonts, and try to throw the error again.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
