[mapserver-users] subsetted output, but I don't want that
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Wed Nov 9 14:35:50 EST 2011
Is the raster georeferenced? It kind of sounds like it is using pixel coordinates instead of coordinates from a spatial reference system.
What do you get if you run gdalinfo on the image file?
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of kablukiw
Sent: Wednesday, November 09, 2011 1:33 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] subsetted output, but I don't want that
I am new to mapserver and am experiencing difficulty with the output being
generated by mapserv.exe (using OSGeo4W). The output I am getting is showing
a subset of the original image even though I am not specifying any extents
that would indicate I want anything other than the full image.
The source file is a global image 1440x720 and the output I get is also
1440x720 but is showing only the bottom left 180x90 pixels of the source
image resized to 720x360 and placed in the upper right of the output image.
http://osgeo-org.1803224.n2.nabble.com/file/n6979235/test.png example output
It seems as if the EXTENT is affecting the extent of the output but I'm not
sure how. I am currently testing this from the cmd line with the following
(I have seen the same issue when testing this mapfile with OpenLayers):
mapserv.exe -nh
"QUERY_STRING=map=c:/OSGeo4W/apache/htdocs/kevin/lst.map&mode=map" >
My map file:
MAP
NAME "LST"
SIZE 1440 720
EXTENT -180 -90 180 90
UNITS DD
SHAPEPATH "c:/OSGeo4W/apache/htdocs/kevin/"
IMAGECOLOR 255 255 255
IMAGETYPE PNG
STATUS ON
DEBUG ON
LAYER
NAME "LST"
TYPE RASTER
STATUS DEFAULT
DATA "lst_1440.png"
OFFSITE 0 0 0
END # LAYER
END # MAP
Any suggestions would be greatly appreciated. Thanks,
Kevin
View this message in context: http://osgeo-org.1803224.n2.nabble.com/subsetted-output-but-I-don-t-want-that-tp6979235p6979235.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
