[mapserver-users] Two Layers not matching up when one is reprojected
Matthew Pettis
matthew.pettis at gmail.com
Wed Nov 9 23:06:40 EST 2011
I am reprojecting a layer of Minnesota county boundaries from epsg:26915 to
be commensurate with a google maps overlay (epsg:3857 aka epsg:900913).
The county overlay is shifted down from the Google Maps map by I'm
guessing to be about 10 miles. Relevant links to map with Openlayers,
straight mapserver map of counties, and the contents of the mapfile for the
counties are below.
My question is: Do I have a data problem, or is it a mapserver
reprojection problem? Or is it a proj4 reprojection problem?
In addition, I am including the epsg codes and the proj.4 equivalents I got
from spatialreference.org and stuck into my proj/epsg file:
# got proj/epsg entries from proj4 link at:
http://spatialreference.org/ref/sr-org/6864/ :
<3785> +proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378137 +b=6378137
+towgs84=0,0,0,0,0,0,0 +units=m +no_defs <>
<3857> +proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378137 +b=6378137
<900913> +proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378137 +b=6378137
Help is much appreciated,
Thanks,
Matt
Map Overlays: http://209.20.85.148/scratch/google-state.htm
Straight mapserver output of county overlay:
http://209.20.85.148/cgi-bin/mapserv?mode=map&map=/var/www/scratch/county-epsg900913.map
County Map (epsg:26916) mapfile (county-epsg900913.map):
MAP
# Map attributes
IMAGETYPE PNG
# epsg:3785 http://spatialreference.org/ref/epsg/3785/proj4/
# Convert
EXTENT -10779406.34 5378456.81 -9951631.67 6334157.39
PROJECTION
"init=epsg:3857"
END
SIZE 700 700
IMAGECOLOR 244 244 244
FONTSET "/home/matt/votevis/mapserver-files/fonts/fonts.list"
# Layers
# Counties
# Renders different thickness borders at different scales
LAYER
NAME "county"
DATA
"/home/matt/votevis/MN/2010-election/shp/shp_counties"
STATUS default
TYPE polygon
PROJECTION
"init=epsg:26915"
END
CLASS
NAME "county_lg"
STYLE
OUTLINECOLOR 111 111 111
COLOR -1 -1 -1
WIDTH 3
END
END
END # Layer county
END # MAP
Do not seek to follow in the footsteps of the wise men of old. Seek what
they sought.
- Matsuo Munefusa (”Basho”)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111109/ca113fe3/attachment.html
