[mapserver-users] Configuring Mapserver in IIS - Anonymous Access?
Brent Fraser bfraser at geoanalytic.com
Tue Nov 15 10:15:02 EST 2011
You need to ensure you've enabled write permissions on the virtual
directory (using IIS).  And I think you'll need to confirm the IIS user
acount (something like IUSR_) can write to the file system folder
(wherever /mapserver/tmp points to).  Use Windows Explorer, right-click
on the folder, look at the Security tab, and give the IUSR_  write
Best Regards,
Brent Fraser
On 11/15/2011 3:19 AM, daz4805 wrote:
> Hi,
> I have a Mapserver virtual directory in C:\inetpub\wwwroot and I am able to
> generate a WMS layer through my site if the virtual directory in IIS has a
> tick for Integrated Windows Authentication under the directory securty tab
> in the properties.
> If i try and configue this virtual directory to be Anonymous Access only, my
> WMS layer does not get created. When I try and navigate to the URL that
> would produce the WMS image, I get an error message regarding not being able
> to open the ms_error.txt file under /Mapserver/tmp. Are there any specific
> permissions i need to set?
> I have tried searching online to see if i can find out how to configure this
> and I've not been successful.
> If somebody could give me a pointer, that would be fantastic.
> Many thanks.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Configuring-Mapserver-in-IIS-Anonymous-Access-tp6995743p6995743.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
