[mapserver-users] Problem with Variable Substitution for EXPRESSION
Prabu Raja prab.raja at gmail.com
Wed Nov 16 06:16:05 EST 2011
Thanks Steve.
Tried the following regular expression
"[-+]?[0-9]*\.?[0-9]+".
For which the internal server error is coming from Apache. No error logged
in mapserver log.  "Internal Server Error
The server encountered an internal error or misconfiguration and was unable
to complete your request."
On Tue, Nov 15, 2011 at 8:37 PM, Lime, Steve D (DNR) <Steve.Lime at state.mn.us
> wrote:
>  See http://www.regular-expressions.info/floatingpoint.html for some good
> examples.****
> Steve****
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Prabu Raja
> *Sent:* Tuesday, November 15, 2011 4:29 AM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Problem with Variable Substitution for
> EXPRESSION****
> Hi,****
> I need to compare one attribute from database table in "EXPRESSION" (under
> "LAYER") with six different values passed as Variable Substitution  for
> coloring the layer.****
> I did added validation for those variables in the map file, but for some
> reason I am getting the below error.****
> *msValidateParameter(): Regular expression error. Parameter pattern
> validation failed.*****
> *msEvalRegex(): Regular expression error. String failed expression test.**
> Could anyone help me with where I am wrong? Below is the map file content
> for this layer. ****
> All the six variables would be numbers (may be a decimal number), Is my
> regular expression correct? ****
> WEB****
>    VALIDATION****
>       value_one     "^[\d+(\.\d)]*$"****
>       value_two     "^[\d+(\.\d)]*$"****
>       value_three   "[^\d+(\.\d)]*$"****
>       value_four    "[^\d+(\.\d)]*$"****
>       value_five    "[^\d+(\.\d)]*$"****
>       value_six     "[^\d+(\.\d)]*$"****
>    END****
> END****
> LAYER ****
>    NAME "state" ****
>    TYPE polygon****
>    STATUS ON ****
>    CONNECTIONTYPE POSTGIS****
>    CONNECTION  "user=postgres password=****** dbname=shpdb host=localhost
> port=5432"****
>    DATA "the_geom FROM  (SELECT gid, the_geom, totpop1 FROM state_shape)
> AS SUBQUERY using unique gid"****
>    PROCESSING "CLOSE_CONNECTION=DEFER"****
>    CLASSITEM "totpop1"****
>    OPACITY 100****
>    CLASS ****
>  EXPRESSION ([TOTPOP1] >= %value_one% AND [TOTPOP1] < %value_two%)****
>  STYLE ****
> COLOR 255 108 118****
> OUTLINECOLOR 255 255 255****
>  END ****
>    END****
>    CLASS****
>       EXPRESSION ([TOTPOP1] >= %value_two% AND [TOTPOP1] < %value_three%)*
>  STYLE ****
> COLOR 254 189 75****
>  END ****
>    END****
>    CLASS ****
>  EXPRESSION ([TOTPOP1] >= %value_three% AND [TOTPOP1] < %value_four%)****
>  STYLE ****
> COLOR 254 247 46 ****
>  END ****
>    END****
>    CLASS ****
>  EXPRESSION ([TOTPOP1] >= %value_four% AND [TOTPOP1] < %value_five%)****
>  STYLE ****
> COLOR 39 251 114****
>  END ****
>    END****
>    CLASS ****
>  EXPRESSION ([TOTPOP1] >= %value_five% AND [TOTPOP1] <= %value_six%)****
>  STYLE ****
> COLOR 108 111 205****
>  END ****
>    END****
> END****
> Regards,
> Prabu Raja****
Regards,
Prabu Raja
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111116/832c87fb/attachment-0001.html
