[mapserver-users] Mapserver WMS client and WMS 1.3.0
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Nov 17 07:12:49 EST 2011
You I do remember but someone really had a WMS 1.3.0 question.
I have had no time for testing cascading WFS 1.1.0 yet. I should make Mapserver to send WFS requests through a logging proxy first for getting some reasonable results. From previous experience I am a bit sceptical but I cannot say much before having a try. Typical things which can go wrong are
- All WFS servers do not necassarily support correctly filters which are sent url-encoded inside http GET requests even they can support them with http POST. I do not know which method Mapserver is using.
- Some WFS servers would rather see PropertyNames given with namespaces
- With WFS 1.1.0 geometries used in spatial filters should follow the official axis order of the corresponding srsName.
- It would be best to give always all the gml geometries explicitly the srsName. Otherwise nobody can really guarantee what srsName the WFS 1.1.0 server is using as default. As far as I remember Mapserver builds filters without srsName.
There are better possibilities for success with cascading WFS 1.0.0 servers but I won't say that it is impossible with WFS 1.1.0. What is essential is to make as simple trial as possible and capture the requests Mapserver is sending. If you play a week or two with different filters and different WFS servers the result to expect is a bunch of bug reports.
-Jukka Rahkonen-
Michal Šrédl wrote:
> Hi Jukka, all,
> I was asking about applying WFS 1.1.0 FES filter (while cascading, but
> this is not the issue). I don't get any error message, rather the
> filter seems not to be applied. Documentation
> (http://mapserver.org/ogc/filter_encoding.html#use-of-filter-e
ncoding-in-mapserver)
> mentions FES 1.0.0, so the question is whether WFS 1.1.0 filtering is
> supported.
> The original email can be found here:
> http://lists.osgeo.org/pipermail/mapserver-users/2011-November
/070726.html
> Thanks a lot,
> Michal
> 2011/11/17 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
> > Hi,
> > Somebody was asking about cascading an external WMS 1.3.0
> server. I remember that the one who asked the questiod had
> captured a rather self-explaining error message like this one
> from our Mapserver 6.0
> > msBuildWMSLayerURL(): WMS connection error. MapServer
> supports only WMS 1.0.0 to 1.1.1 (please verify the VERSION
> parameter in the connection string).
> > Perhaps it would be still worth adding a line about
> supported versions into the Limitations/TODO in document
> http://mapserver.org/ogc/wms_client.html
> > -Jukka Rahkonen-
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
