[mapserver-users] style level opacity issue
Huotari, John B (RCIS)
John.Huotari at RCIS.com
Fri Nov 18 13:35:19 EST 2011
Now I'm really confused... When I define the layer in the mapfile as follows it displays semi-transparent just fine using class-level opacity.
LAYER
NAME "Field"
TYPE polygon
DATA "MAPFIELD"
STATUS on
PROJECTION
"proj=longlat" "ellps=GRS80" "datum=NAD83"
END
CLASS
NAME "FieldClass"
STYLE
SYMBOL 0
WIDTH 1
OUTLINECOLOR 0 0 0
COLOR 0 255 0
OPACITY 50
END
END
END
But when I add the layer to the map using mapscript as follows it is entirely opaque.
Dim fieldLayer As New OSGeo.MapServer.layerObj(map)
With fieldLayer
.data = dataLocation & "MAPFIELD"
.name = "Field"
.type = MS_LAYER_TYPE.MS_LAYER_POLYGON
.status = 1
.setProjection("+proj=longlat +ellps=GRS80 +datum=NAD83 +no_defs")
Dim fieldClass As New OSGeo.MapServer.classObj(fieldLayer)
With fieldClass
.name = "FieldClass"
Dim fieldStyle As New OSGeo.MapServer.styleObj(fieldClass)
With fieldStyle
.symbol = 0
.width = 1
.outlinecolor = New colorObj(0, 0, 0, 0)
.color = New colorObj(0, 255, 0, 0)
'set the opacity on the style
.opacity = 50
End With
End With
End With
Does anyone see what I've done wrong?
I've created a trivial Visual Studio 2010 project which reproduces the behavior I could send to anyone who might have an interest in seeing it. All zipped up including the MapServer binaries (from MS4W version 3.0.3) and a little bit of data it is less than 2 MB in size.
Thank you,
John
-----Original Message-----
From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sent: Thursday, November 17, 2011 1:17 PM
To: Huotari, John B (RCIS)
Cc: lists at killface.org; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] style level opacity issue
I've just run a quick check and opacity on the style object works correctly. please come up with a self contained test case that reproduces your issue.
regards,
thomas
On Thu, Nov 17, 2011 at 18:15, Huotari, John B (RCIS)
<John.Huotari at rcis.com> wrote:
> I’d likewise like to see an answer to this as I’ve thus far been
> unable to make opacity work at the style level. I’ve worked around
> that by using the opacity at the layer level instead, which might be a
> suitable solution in your situation.
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> Sent: Thursday, November 17, 2011 10:02 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] style level opacity issue
> I'm trying to render a single vector layer that has overlapping
> polygons, but I cant seem to get the settings correct for what I want.
> There are overlapping polygons on the layer, and I would like them to
> each be drawn transparently so that I can see the overlapping regions.
> However, no matter what I try I can't seem to get this effect and the
> rendering will make the shapes draw over each other.
> I'm using Mapserver 6.0.1
> OUTPUTFORMAT
> NAME "png"
> DRIVER AGG/PNG
> MIMETYPE "image/pngt"
> IMAGEMODE RGBA
> EXTENSION "png"
> FORMATOPTION "GAMMA=1.0"
> TRANSPARENT TRUE
> END
> I have a very simple class for my layer
> CLASS
> STYLE
> OPACITY 25
> COLOR [color]
> OUTLINECOLOR -1 -1 -1
> ANTIALIAS TRUE
> END
> LABEL
> COLOR 0 0 255
> OUTLINECOLOR 250 250 250
> OUTLINEWIDTH 3
> FONT stMYFont
> TYPE truetype
> SIZE 9
> POSITION AUTO
> PARTIALS FALSE
> MINFEATURESIZE AUTO
> END
> END
