[mapserver-users] mapcache in a cluster
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Nov 21 11:12:37 EST 2011
Travis,
In the past I have used NFS in a custer and in general the performance
was very bad when compared to SMB. Now this was a few years ago, ie: not
using mapcache, but my experience was that we ran into a few issues with
NFS:
1. NFS CPU overhead was significantly more
2. connection recovery was poor if a server was pulled from the cluster
and added back again (ie: recovery after an error condition)
3. the protocol seems to have a lot more over head
-Steve W
On 11/21/2011 9:39 AM, thomas bonfort wrote:
> What kind of performance issues? The current locking code only uses
> the presence/absence of a file for it's locking functions, and does
> not rely on flock/fcntl.
> thomas
> On Mon, Nov 21, 2011 at 15:16, Travis Kirstine<traviskirstine at gmail.com> wrote:
>> Thomas,
>> We have been running into some performance issues mapcache and nfs.
>> We feel the issue may be related to how nfs locks files/directories
>> compared to smb. We are trying a few thing on our end (disable
>> locking / nfs4 etc). Do you have any ideas?
>> Regards
>> On 20 October 2011 12:19, thomas bonfort<thomas.bonfort at gmail.com> wrote:
>>> So, this discussion inspired me to completely rework the locking
>>> mechanism in mapcache, to stop relying on file locks which have their
>>> quirks on network filesystems.
>>> I have tried using multiple apache instances configured to used a
>>> SMB-mounted lock directory and hammered both instances on unseeded
>>> identical area to force locking, and ended up with absolutely no
>>> duplicate wms requests or failed requests for the clients.
>>> The code is committed in trunk. Thanks for bringing this up, this
>>> allowed me to really simplify the locking code and remove a lot of
>>> unneeded stuff :)
>>> thomas
>>> On Thu, Oct 20, 2011 at 17:08, Travis Kirstine<traviskirstine at gmail.com> wrote:
>>>> Andreas and Thomas
>>>> Thanks for you responses, I have discussed this with some of our IT
>>>> staff and they had similar solution as Andreas using gfs. Their
>>>> comments are below:
>>>> "I suspect this scheme is not reliable over NFS. The problem is the
>>>> directory updates are not synchronized across multiple nodes. I had a
>>>> similar issue with the IMAP E-mail protocol. Our workaround currently
>>>> is to force each user to leverage a single server.
>>>> Ref:
>>>> http://wiki.dovecot.org/NFS
>>>> Seems like there's some tweaks to disable directory attribute caching
>>>> but this can trigger slower performance.
>>>> Only workaround is to use GFS which I found to have it's own issues. "
>>>> Regards
>>>> On 20 October 2011 05:32, Eichner, Andreas - SID-NLKM
>>>> <Andreas.Eichner at sid.sachsen.de> wrote:
>>>>> We use TileCache.py on two servers with the cache on an OCFS2 on a
>>>>> shared LUN in the SAN. No known issues with that for now. Note: Spurious
>>>>> stale lock files occurred already on a single machine. There seemed to
>>>>> be issues with lots of requests and a very slow upstream server. I used
>>>>> a cron job to delete lock files older than 5 minutes or so.
>>>>> As Thomas noted, if the lock files are created on a shared filesystem
>>>>> and you make sure the filesystem you use is able to lock files properly
>>>>> (read the docs carefully!) there's no reason why it should not work.
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
