[mapserver-users] Problem with Variable Substitution for
EXPRESSION
Prabu Raja
prab.raja at gmail.com
Tue Nov 22 04:25:42 EST 2011
Hi Steve / Daniel,
I am using ms4w from http://maptools.org/ms4w/index.phtml in Windows 7.
Following is my map file content.
MAP
NAME ms_sql
IMAGECOLOR 255 255 255
# default output image dimensions
SIZE 256 256
# Is the map active? Sometimes you may wish to turn this off to
# use only the reference map or scale bar.
STATUS ON
CONFIG "MS_ERRORFILE" "\var\Map\error.txt"
DEBUG 0
# set top level projection
PROJECTION
"init=epsg:4326"
END
# image format options
OUTPUTFORMAT
NAME "png"
DRIVER AGG/PNG
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
TRANSPARENT ON
FORMATOPTION "GAMMA=0.75"
END
EXTENT -180 -90 180 90 # World
LAYER
VALIDATION
'V1' '^[-+]?[0-9]*\.?[0-9]+$'
'V2' '^[-+]?[0-9]*\.?[0-9]+$'
'V3' '^[-+]?[0-9]*\.?[0-9]+$'
'V4' '^[-+]?[0-9]*\.?[0-9]+$'
'V5' '^[-+]?[0-9]*\.?[0-9]+$'
'V6' '^[-+]?[0-9]*\.?[0-9]+$'
END
NAME "state"
TYPE polygon
STATUS ON
CONNECTIONTYPE POSTGIS
CONNECTION "host=localhost dbname=pollutionmap user=*** password=***
port=5432"
DATA "wkb_geometry FROM (SELECT ogc_fid AS
oid, wkb_geometry, totpop1 FROM state_tst) AS SUBQUERY using unique oid"
PROCESSING "CLOSE_CONNECTION=DEFER"
CLASSITEM "totpop1"
OPACITY 100
CLASS
EXPRESSION ([TOTPOP1] >= %V1% AND [TOTPOP1] < %V2%)
STYLE
COLOR 255 108 118
OUTLINECOLOR 255 255 255
END
END
CLASS
EXPRESSION ([TOTPOP1] >= %V2% AND [TOTPOP1] < %V3%)
STYLE
COLOR 254 189 75
END
END
CLASS
EXPRESSION ([TOTPOP1] >= %V3% AND [TOTPOP1] < %V4%)
STYLE
COLOR 254 247 46
END
END
CLASS
EXPRESSION ([TOTPOP1] >= %V4% AND [TOTPOP1] < %V5%)
STYLE
COLOR 39 251 114
END
END
CLASS
EXPRESSION ([TOTPOP1] >= %V5% AND [TOTPOP1] <= %V6%)
STYLE
COLOR 108 111 205
END
END
END
END
Below are the url's through I am trying to generate map
http://localhost/fcgi-bin/mapserv.exe?map=/var/Map/State.map&layers=state&mode=map&V1=60650.45&V2=33288104.54&V3=66515558.222&V4=99743012.123&V5=132970466.455&V6=166197921.245
http://localhost/fcgi-bin/mapserv.exe?map=/var/Map/State.map&layers=state&mode=map&V1=60650&V2=33288104&V3=66515558&V4=99743012&V5=132970466&V6=166197921
Accessing through above 2 url gives '500 Internal Server Error'.
No error message in mapserver log.
Following error message logged in apache error log.
[warn] [client 127.0.0.1] (OS 109)The pipe has been ended. : mod_fcgid:
get overlap result error
[error] [client 127.0.0.1] Premature end of script headers: mapserv.exe
And following was logged in appache access log
GET
HTTP/1.1" 500 533
On Wed, Nov 16, 2011 at 9:14 PM, Daniel Morissette <dmorissette at mapgears.com
> wrote:
> Which binaries are you using?
> If you your own custom build then are you sure it's not a case of multiple
> versions of REGEX on the same system? That used to be a problem in the old
> days with PHP's local copy of regex conflicting with the system regex, but
> I don't think that is a problem any more though.
> On 11-11-16 10:40 AM, Lime, Steve D (DNR) wrote:
>> Well, that’s not good is it. Hmmm… I ran a quick test here using this
>> mapfile:
>> MAP
>> NAME 'test'
>> SIZE 450 600
>> EXTENT 125000 4785000 788000 5489000
>> IMAGETYPE PNG8
>> LAYER
>> VALIDATION
>> 'area' '^[-+]?[0-9]*\.?[0-9]+$'
>> END
>> NAME 'county'
>> STATUS DEFAULT
>> TYPE POLYGON
>> DATA ' bdry_counpy2'
>> CLASS
>> EXPRESSION ([area] > %area%)
>> STYLE COLOR 212 212 212 OUTLINECOLOR 0 0 0 END
>> END
>> END
>> END
>> This is against 6.0 latest trunk although I don’t think there have been
>> any changes in that area…
>> I can run something like:
>> mapserv -nh "QUERY_STRING=map=test.map&**mode=map&area=500000000" >
>> If ‘area’ parameter is provided as a non-double then the substitution
>> isn’t done. I believe the substitution validation errors fail silently.
>> This example works, how different is what you’re doing?
>> Steve
>> *From:*Prabu Raja [mailto:prab.raja at gmail.com]
>> *Sent:* Wednesday, November 16, 2011 5:16 AM
>> *To:* Lime, Steve D (DNR)
>> *Cc:* mapserver-users at lists.osgeo.**org <mapserver-users at lists.osgeo.org>
>> *Subject:* Re: [mapserver-users] Problem with Variable Substitution for
>> EXPRESSION
>> Thanks Steve.
>> Tried the following regular expression
>> "[-+]?[0-9]*\.?[0-9]+".
>> For which the internal server error is coming from Apache. No error
>> logged in mapserver log.
>> "Internal Server Error
>> The server encountered an internal error or misconfiguration and was
>> unable to complete your request.*"*
>> On Tue, Nov 15, 2011 at 8:37 PM, Lime, Steve D (DNR)
>> <Steve.Lime at state.mn.us <mailto:Steve.Lime at state.mn.us**>> wrote:
>> See http://www.regular-**expressions.info/**floatingpoint.html<http://www.regular-expressions.info/floatingpoint.html>for some good
>> examples.
>> Steve
>> *From:*mapserver-users-**bounces at lists.osgeo.org<mapserver-users-bounces at lists.osgeo.org>
>> <mailto:mapserver-users-**bounces at lists.osgeo.org<mapserver-users-bounces at lists.osgeo.org>
>> [mailto:mapserver-users-**bounces at lists.osgeo.org<mapserver-users-bounces at lists.osgeo.org>
>> <mailto:mapserver-users-**bounces at lists.osgeo.org<mapserver-users-bounces at lists.osgeo.org>>]
>> *On Behalf Of *Prabu Raja
>> *Sent:* Tuesday, November 15, 2011 4:29 AM
>> *To:* mapserver-users at lists.osgeo.**org <mapserver-users at lists.osgeo.org>
>> <mailto:mapserver-users at lists.**osgeo.org<mapserver-users at lists.osgeo.org>
>> *Subject:* [mapserver-users] Problem with Variable Substitution for
>> EXPRESSION
>> Hi,
>> I need to compare one attribute from database table in "EXPRESSION"
>> (under "LAYER") with six different values passed as Variable
>> Substitution for coloring the layer.
>> I did added validation for those variables in the map file, but for some
>> reason I am getting the below error.
>> *msValidateParameter(): Regular expression error. Parameter pattern
>> validation failed.*
>> *msEvalRegex(): Regular expression error. String failed expression test.*
>> validation failed.*
>> Could anyone help me with where I am wrong? Below is the map file
>> content for this layer.
>> All the six variables would be numbers (may be a decimal number), Is my
>> regular expression correct?
>> WEB
>> VALIDATION
>> value_one "^[\d+(\.\d)]*$"
>> value_two "^[\d+(\.\d)]*$"
>> value_three "[^\d+(\.\d)]*$"
>> value_four "[^\d+(\.\d)]*$"
>> value_five "[^\d+(\.\d)]*$"
>> value_six "[^\d+(\.\d)]*$"
>> END
>> END
>> LAYER
>> NAME "state"
>> TYPE polygon
>> STATUS ON
>> CONNECTION "user=postgres password=****** dbname=shpdb host=localhost
>> port=5432"
>> DATA "the_geom FROM (SELECT gid, the_geom, totpop1 FROM state_shape) AS
>> SUBQUERY using unique gid"
>> CLASSITEM "totpop1"
>> OPACITY 100
>> CLASS
>> EXPRESSION ([TOTPOP1] >= %value_one% AND [TOTPOP1] < %value_two%)
>> STYLE
>> COLOR 255 108 118
>> END
>> END
>> CLASS
>> EXPRESSION ([TOTPOP1] >= %value_two% AND [TOTPOP1] < %value_three%)
>> STYLE
>> COLOR 254 189 75
>> END
>> END
>> CLASS
>> EXPRESSION ([TOTPOP1] >= %value_three% AND [TOTPOP1] < %value_four%)
>> STYLE
>> COLOR 254 247 46
>> END
>> END
>> CLASS
>> EXPRESSION ([TOTPOP1] >= %value_four% AND [TOTPOP1] < %value_five%)
>> STYLE
>> COLOR 39 251 114
>> END
>> END
>> CLASS
>> EXPRESSION ([TOTPOP1] >= %value_five% AND [TOTPOP1] <= %value_six%)
>> STYLE
>> COLOR 108 111 205
>> END
>> END
>> END
>> Regards,
>> Prabu Raja
>> Regards,
>> Prabu Raja
>> ______________________________**_________________
>> mapserver-users mailing list
>> http://lists.osgeo.org/**mailman/listinfo/mapserver-**users<http://lists.osgeo.org/mailman/listinfo/mapserver-users>
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
Regards,
Prabu Raja
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111122/64866caf/attachment.html
