[mapserver-users] Some PointSymbolizer values are being ignored.
SLD Syntax problem?
myOpenLayersUName
joanne.mcgraw at SYMPATICO.CA
Thu Nov 24 11:43:54 EST 2011
Hello all,
Hopefully, this is a quickie and there's just something wrong with my SLD
syntax that I can't see.
I have a map file with a layer that has a single point in it. I am trying to
apply an SLD to it using the following URL:
http://<mydomain>/ogc/myWms&LAYERS=Point&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A42304&BBOX=-2903297.000,-789911.0000,3431059.000,3959683.000&WIDTH=256&HEIGHT=256&sld=http://<mydomain>/agmaf/PointSld.xml
The content of the PointSld.xml is:
In the resulting image, the point's fill-opacity, stroke-opacity and
stroke-width values are being ignored, although its stroke and fill colours
are correct.
I've tried changing around the SLD but generally just seem to cause more
problems. Is there something obviously wrong with the syntax that I'm just
not seeing? It looks correct to me...but then it always does, doesn't it?
I am using Mapserver 6.0.1.
Cheers,
jtm
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Some-PointSymbolizer-values-are-being-ignored-SLD-Syntax-problem-tp7028772p7028772.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
