[mapserver-users] RE: WCS GetCoverage
David Hildebrand David.Hildebrand at afsc.ca
Thu Nov 24 16:25:06 EST 2011
Jukka:
I am running MapServer 5.2.1 and am being explicit about W** version.
For WMS I am using version 1.1.1 and WCS version 1.0.0 but that is
hidden in a CGI wrapper.  I did find out, however, that in my WCS
request I need to specify the RESX and RESY units the same as the CRS
projection units (in this case degrees) and I also need to specify the
RESPONSE_CRS the same as the CRS.  These are odd behaviours.  One should
be able to request the response in a different projection than the
bounding box and specify the resolution in the units of the output
projection.  The projections I am using are all specified in the
"ows_srs" line of the mapserv.map file.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
-----Original Message-----
From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
Sent: Thursday, November 24, 2011 2:06 PM
To: David Hildebrand; mapserver-users at lists.osgeo.org
Subject: Re: WCS GetCoverage
Very first thing to do with all the W** services is to give always an
explicit VERSION=
Request can sometimes work even without but then the default is the
highest supported.  Do not play with defaults, take the control for
yourself.
What Mapserver version you have? Perhaps some old 5.x which supports
only WCS 1.0 because otherwise I suppose you would get some other error
message with your request.
-Jukka Rahkonen-
David Hildebrand wrote:
I am trying to implement a WCS server and am running into difficulty
with GetCoverage and the following request.
REQUEST=GetCoverage&COVERAGE=awifs&CRS=EPSG:4269&BBOX=-116,51,-114,53&RE
SX=100&RESY=100&FORMAT=GTiff&RESPONSE_CRS=EPSG:4269
The following ServiceException is raised.
msImageCreateGD(): Image handling error. Cannot create GD image of size
0x0
I can do a WCS GetCapabilities and DescribeCoverage without error.
Also, when I issue the following WMS request it works fine.
REQUEST=GetMap&LAYERS=awifs&SRS=EPSG:4269&BBOX=-116,51,-114,53&WIDTH=800
&HEIGHT=600&FORMAT=image/png&STYLES=
The GetCoverage and GetMap requests have the same parameters and yet WCS
thinks the image size is 0x0.  The MapServer configuration for the layer
file is given below
LAYER
  NAME "awifs"
  PROCESSING "BANDS=2,1,3"
  PROCESSING "SCALE_2=19,159"
  PROCESSING "SCALE_1=10,130"
  PROCESSING "SCALE_3=9,124"
  METADATA
    "wcs_label" "awifs"
    "wcs_rangeset_name" "RGB"
    "wcs_rangeset_label" "rgb"
    "wms_title" "awifs"
    "wms_opaque" "1"
    "ows_resolution" "56 56"
    "wms_srs" "EPSG:43001"
  END
  STATUS off
  TYPE raster
  DATA "e:/awifs/July.tif"
  PROJECTION
    "init=epsg:43001"
  END
  TEMPLATE "empty.html"
  DUMP TRUE
END
Thanks for the help.
David V. Hildebrand
(403) 782-8239
