[mapserver-users] comment out large section of map file
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Sun Nov 27 23:54:01 EST 2011
A workaround is to write the large section into separate text file and add it into the main mapfile with INCLUDE. Then there would be only one line to comment out. I am nowadays adding almost all layers as includes. It makes it easy to re-use the same layers in several mapfiles.
-Jukka Rahkonen-
Matt McClelland wrote:
> Hi All
> I notice you can comment one line in a mapfile using a #
> Is there a way of commenting out a large section like in PHP where you use /* */ ??
> It would be handing when working on large map files.
> Matt :)
