[mapserver-users] MapCache: Disabling WMS requests for
fully-seeded caches?
John Taranu
jtaranu at firstbasesolutions.com
Tue Nov 29 11:32:35 EST 2011
Hi Thomas,
Thanks for the suggestion. Commenting out the source block disables the WMS requests.
However, the error reporting seems to be broken. Setting <errors>empty_img</errors> crashes Apache with a segmentation fault (mod_mapcache SVN revision 12828). Setting <errors>report</errors> throws HTTP 404 responses, which is a more reasonable result.
John
-----Original Message-----
From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sent: Tuesday, November 29, 2011 10:33 AM
To: John Taranu
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] MapCache: Disabling WMS requests for fully-seeded caches?
You can do this by commenting out the <source> block from the tileset once the wanted tiles have been created. You'll probably also want set error reporting to return blank images from that stage onwards.
thomas
On Tue, Nov 29, 2011 at 00:09, John Taranu <jtaranu at firstbasesolutions.com> wrote:
> We have a fully seeded cache that was fully seeded to a polygon outline.
> The intent is to serve the tileset through a variety of services (WMS,
> TMS) using mod-mapcache.
> Tiles that are outside the polygon outline but still within the
> polygon bounding box should be blank tiles. However, a request for
> one of these tiles results in a call to that tileset’s WMS source.
> This creates considerable overhead by starting up MapServer and
> writing the resulting tile to the cache. Is there any way to disable
> the WMS calls for these blank tiles, and instead short-circuit the
> request to return a blank? That is, once a tileset has been fully
> seeded, is it possible to disable any further calls to the WMS, so
> that requests for tiles that are not in the cache return a blank?
