[mapserver-users] MapCache: Disabling WMS requests for
fully-seeded caches?
John Taranu
jtaranu at firstbasesolutions.com
Tue Nov 29 15:22:44 EST 2011
Note that setting the default format to PNG doesn't cause a segmentation
fault:
<default_format>PNG</default_format>
<errors>empty_img</errors>
However, in this case mapcache still returns a HTTP 404 instead of a blank
image.
-----Original Message-----
From: Travis Kirstine [mailto:traviskirstine at gmail.com]
Sent: Tuesday, November 29, 2011 3:21 PM
To: thomas bonfort
Cc: John Taranu; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] MapCache: Disabling WMS requests for
Thomas,
Here is the backtrace:
(gdb) run -X
Starting program: /usr/sbin/httpd -X
warning: no loadable sections found in added symbol-file system-supplied DSO
at 0x2aaaaad1b000 [Thread debugging using libthread_db enabled]
Program received signal SIGSEGV, Segmentation fault.
0x00002aaaaca4e32b in strstr () from /lib64/libc.so.6
(gdb) bt
#0 0x00002aaaaca4e32b in strstr () from /lib64/libc.so.6
#1 0x00002aaab539737d in mapcache_image_create_empty () from
/usr/lib64/httpd/modules/mod_mapcache.so
#2 0x00002aaab53971fe in mapcache_configuration_parse_xml () from
#3 0x00002aaab53a047a in mapcache_configuration_parse () from
#4 0x00002aaab53879e6 in mapcache_add_alias (cmd=0x7fffffffe760, cfg=<value
optimized out>, alias=0x2aaaaae0f850 "/mapcache",
configfile=0x2aaaaae0f860 "/var/www/html/mapcache/mapcache.xml")
at mod_mapcache.c:502
#5 0x00002aaaaaad5c4b in ?? ()
#6 0x00002aaaaaad60d0 in ap_walk_config ()
#7 0x00002aaaaaad6232 in ap_process_config_tree ()
#8 0x00002aaaaaac1c51 in main ()
(gdb)
MapCache snippet:
<default_format>mixed</default_format>
Regards
On 29 November 2011 11:56, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> I've just tried report_img locally without issues, any chance you can
> provide a backtrace ?
> On Tue, Nov 29, 2011 at 17:32, John Taranu
> <jtaranu at firstbasesolutions.com> wrote:
>> Hi Thomas,
>> Thanks for the suggestion. Commenting out the source block disables the
WMS requests.
>> However, the error reporting seems to be broken. Setting
<errors>empty_img</errors> crashes Apache with a segmentation fault
(mod_mapcache SVN revision 12828). Setting <errors>report</errors> throws
HTTP 404 responses, which is a more reasonable result.
>> John
>> From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
>> Sent: Tuesday, November 29, 2011 10:33 AM
>> To: John Taranu
>> Cc: mapserver-users at lists.osgeo.org
>> You can do this by commenting out the <source> block from the tileset
once the wanted tiles have been created. You'll probably also want set error
reporting to return blank images from that stage onwards.
>> thomas
>> On Tue, Nov 29, 2011 at 00:09, John Taranu
>>> We have a fully seeded cache that was fully seeded to a polygon outline.
>>> The intent is to serve the tileset through a variety of services
>>> (WMS,
>>> TMS) using mod-mapcache.
>>> Tiles that are outside the polygon outline but still within the
>>> polygon bounding box should be blank tiles. However, a request for
>>> one of these tiles results in a call to that tilesets WMS source.
>>> This creates considerable overhead by starting up MapServer and
>>> writing the resulting tile to the cache. Is there any way to
>>> disable the WMS calls for these blank tiles, and instead
>>> short-circuit the request to return a blank? That is, once a
>>> tileset has been fully seeded, is it possible to disable any further
>>> calls to the WMS, so that requests for tiles that are not in the cache
return a blank?
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
