[mapserver-users] WMS LAYERS parameter - problems with the order
Daniel Degasperi daniel.degasperi at r3-gis.com
Wed Nov 30 05:04:39 EST 2011
ok, this setting solved my problem.
Thank you very much!
Best regards,
Daniel
Am 30/11/2011 09:54, schrieb Jana Golinowski:
> I think this one is causing your problem:
>> POSTLABELCACHE TRUE
> According to the docs MapServer is acting correctly: "Tells MapServer
> to render this layer after all labels in the cache have been drawn."
> Your point layer contains labels. So your polygon layer will always be
> drawn afterwards.
> Greetings, Jana.
> mapserver-users at lists.osgeo.org
*Daniel Degasperi*
*R3 GIS* Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
web: www.r3-gis.com <http://www.r3-gis.com/>
Email: daniel.degasperi at r3-gis.com <mailto:daniel.degasperi at r3-gis.com>
Tel. : +39 0473 494949
Fax : +39 0473 069902
*ATTENZIONE!* Le informazioni contenute nella presente e-mail e nei
documenti eventualmente allegati sono confidenziali. La loro diffusione,
distribuzione e/o riproduzione da parte di terzi, senza autorizzazione
del mittente è vietata e può violare il D. Lgs. 196/2003. In caso di
ricezione per errore, Vogliate immediatamente informare il mittente del
messaggio e distruggere la e-mail.
*ACHTUNG!* Die in dieser Nachricht oder in den beigelegten Dokumenten
beinhalteten Informationen sind streng vertraulich. Ihre Verbreitung
und/oder ihre Wiedergabe durch Dritte ist ohne Erlaubnis des Absenders
verboten und verstößt gegen das Legislativdekret 196/2003. Sollten Sie
diese Mitteilung irrtümlicherweise erhalten haben, bitten wir Sie uns
umgehend zu informieren und anschließend die Mitteilung zu vernichten.
*WARNING!* This e-mail may contain confidential and/or privileged
information. If you are not the intended recipient (or have received
this e-mail in error) please notify the sender immediately and destroy
this e-mail. Any unauthorised copying, disclousure or distribution of
the material in this e-mail is strictly forbidden and could be against
the law (D. Lgs. 196/2003)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111130/8f006eb3/attachment.html
