[mapserver-users] Itemnquery slow in big TAB file;
slow on Oracle as well
Bart van den Eijnden
bartvde at osgis.nl
Mon Oct 3 04:59:50 EDT 2011
Hi Jelmer,
I don't know about MapInfo, but for Oracle you can skip the spatial filter by adding
USING NONE
to your DATA statement. See:
http://mapserver.org/input/vector/oracle.html
Best regards,
Bart
OSGIS - http://osgis.nl
On Oct 3, 2011, at 10:46 AM, Jelmer Baas wrote:
> Hello List,
> I have a query to retrieve geometry from a TAB file:
> mapserv.exe?mode=itemquery&map= query.map&mapext=-70000+280000+500000+700000&layers=MYLAYER&qlayer= MYLAYER &qstring=('[IDCOLUMN]' IN '2550643')
> This is my simplified Layer definition:
> LAYER
> NAME MYLAYER
> TYPE LINE
> CONNECTIONTYPE OGR
> CONNECTION "c:\temp\MYLAYER.TAB"
> CLASS
> NAME "Test"
> END
> METADATA
> qstring_validation_pattern '^'
> END
> END
> To query this TAB file, MapServer needs about 20 seconds. MapInfo needs about 20ms, so MapServer is obviously not using the index on this column.
> I tried changing this to Oracle Spatial, but then I bump into another problem: the query contains a spatial clause (which isn't needed):
> SELECT IDCOLUMN FROM MYLAYER WHERE 'IDCOLUMN' IN '2550643' AND SDO_FILTER( GEOLOC, MDSYS.SDO_GEOMETRY(2003, 90112, NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-70000,280000,500000,700000) ),'querytype=window') = 'TRUE'
> This also takes about 10 seconds. Without the AND SDO_FILTER() part it takes a few milliseconds.
> So two questions, I guess. Can I make MapServer use the index on the IDCOLUMN column, and, can I tell Mapserver to skip the SDO_FILTER part on Oracle?
> Oh, I'm currently using MapServer 5.6 but tried 6.0 as well.
> Thank you,
> Regards,
> Jelmer Baas
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111003/eed3758a/attachment.html
