[mapserver-users] Projection library error. no system list, errno: 2
Richard Greenwood richard.greenwood at gmail.com
Mon Oct 3 09:06:10 EDT 2011
Thanks Daniel! That was it and I feel suitably stupid.As always I
appreciate your help.
Rich
On Mon, Oct 3, 2011 at 6:13 AM, Daniel Morissette
<dmorissette at mapgears.com> wrote:
> What does your PROJECTION block look like?
> Could it be that you used something like "init=EPSG:4326"? Linux is
> case-sensitive and the argument to the init=... param is a filename so you
> must use a lowercase "epsg" in the init string, e.g. "init=epsg:4326"
> On 11-10-02 03:59 PM, Richard Greenwood wrote:
>> All-
>> I'm getting the following error from mapserver:
>>    msProcessProjection(): Projection library error. no system list, errno:
>> 2
>> I have a fresh install of Ubuntu Lucid with standard mapserer&  gdal
>> packages. I see
>>    /usr/share/proj/epsg
>> which includes the EPSG code that I am referencing.
>> I have added
>>    CONFIG PROJ_LIB "/usr/share/proj/"
>> to my map file.
>> cs2cs in the shell seems to find and use the epsg file.
>> I have even tried changing the ownership of the epsg file to www-data
>> (the Ubuntu web account). I don't see any PROJ_LIB definitions in the
>> apache *.conf files.
>> So I'm kind of at my wits end. Any suggestions?
>> Thanks,
>> Rich
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
> mapserver-users at lists.osgeo.org
Richard Greenwood
www.greenwoodmap.com
