[mapserver-users] graticule label position
Shorthouse, David dshorthouse at eol.org
Wed Oct 5 12:30:50 EDT 2011
To be clear, I'm using PHP-mapscript (no mapfile at all) and MapServer
5.6.6. Was this known behavior and since fixed in 6.0.x? If so, I'm
all over that!
Dave
(apologies for this note in your Inbox a second time Brent, "replied
all" w/o first checking what account I was using)
> On Wed, Oct 5, 2011 at 12:18 PM, Brent Fraser <bfraser at geoanalytic.com> wrote:
>> Ok, that's a bug.  Can you send me your map file?
>> Best Regards,
>> Brent Fraser
>> On 10/5/2011 10:15 AM, Shorthouse, David wrote:
>>> Brent,
>>> Tics are not so much a big deal. If I understand correctly, something
>>> like this cannot be avoided?
>>> http://www.simplemappr.net/?map=1110
>>> What I'd rather have is the labels positioned around the outside edge
>>> of the image (i.e. horizontally and vertically) rather than arcing and
>>> disappearing.
>>> Thanks,
>>> Dave
>>> On Wed, Oct 5, 2011 at 11:53 AM, Brent Fraser<bfraser at geoanalytic.com>
>>>  wrote:
>>>> David,
>>>>  If you mean a specific number of pixels from your neat line, the answer
>>>> is
>>>> no.  Currently the graticule logic fixes the location from the edge of
>>>> the
>>>> image (i.e. the other side of the label).  And it doesn't do tics.
>>>> Best Regards,
>>>> Brent Fraser
>>>> On 10/5/2011 8:44 AM, Shorthouse, David wrote:
>>>>> Folks,
>>>>> Is it possible to fix the position of graticule labels around the
>>>>> outside edge of a map in the face of on-the-fly reprojections of a shp
>>>>> file? Following a hint in a very old post in the archives, I managed
>>>>> to make fixed margin around the outside edge of a map where I hoped I
>>>>> could place graticule labels, but unless I can actually fix their
>>>>> position, there's not much I can do. This is an example of what I am
>>>>> trying to do:
>>>>> http://www.geo.wvu.edu/~mfinkenbinder/Geol%20321/UTM_Zones.bmp
>>>>> Thanks,
>>>>> Dave
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
