[mapserver-users] MapCache - failed to remove lockfile error
Travis Kirstine traviskirstine at gmail.com
Thu Oct 6 16:17:02 EDT 2011
This doesn't seem to be a issue, I have lots of inodes left.  It
appears that the error occurred when generating (linking)  areas with
a large volume of transparent tiles, could this be related?
Regards
On 6 October 2011 14:19, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Have you verified that you have not filled up the disk or run out of inodes?
> # check the diskspace with
> df -h
> # check for inode issues
> touch /path/to/cache/test.junk
> # if the touch failed then you have run out of inodes
> # otherwise clean up
> rm /path/to/cache/test.junk
> Thanks,
>  -Steve W
> On 10/6/2011 12:14 PM, thomas bonfort wrote:
>> I don't have a specific advice to give unfortunately. There have been
>> some fixes lately (macpcache only, not mod-geocache) to the way
>> multiple threads accessed the curl library that might help, so you
>> might want to try with a fresh checkout from the mapserver svn.
>> thomas
>> On Thu, Oct 6, 2011 at 18:08, Travis Kirstine<traviskirstine at gmail.com>
>>  wrote:
>>> Thomas,
>>> My command is below, I'm using a disk cache, my config file is below.
>>> I'm using a local copy of MapServer for the source image generation
>>> ./geocache_seed -c ../geocache.xml -t ms_tileset_8 -z 0,21 -e
>>> -8895580.772,5411569.158,-8797157.196,5538966.276 -n 6
>>> <?xml version="1.0" encoding="UTF-8"?>
>>> <geocache>
>>>   <metadata>
>>>      <title>geocache service esx11</title>
>>>      <abstract>mod-geocache service</abstract>
>>>      <!-- url>http://mysuperhost/proxy/to/geocache</url -->
>>>   </metadata>
>>>         <grid name="googlemaps_grid">
>>>            <metadata>
>>>               <title>GoogleMapsCompatible</title>
>>> <WellKnownScaleSet>urn:ogc:def:wkss:OGC:1.0:GoogleMapsCompatible</WellKnownScaleSet>
>>>            </metadata>
>>>            <extent>-20037508.3427892480 -20037508.3427892480
>>> 20037508.3427892480 20037508.3427892480</extent>
>>>            <srs>EPSG:3857</srs>
>>>            <srsalias>EPSG:900913</srsalias>
>>>            <units>m</units>
>>>            <size>256 256</size>
>>>            <resolutions>156543.0339280410 78271.51696402048
>>> 39135.75848201023 19567.87924100512 9783.939620502561
>>> 4891.969810251280 2445.984905125640 1222.992452562820
>>> 611.4962262814100 305.7481131407048 152.8740565703525
>>> 76.43702828517624 38.21851414258813 19.10925707129406
>>> 9.554628535647032 4.777314267823516 2.388657133911758
>>> 1.194328566955879 0.5971642834779395 0.29858214173896975
>>> 0.149291070869484875 0.0746455354347424375</resolutions>
>>>         </grid>
>>>   <cache name="disk" type="disk">
>>>      <base>/var/mod-geocache/caches</base>
>>>      <symlink_blank/>
>>>   </cache>
>>>   <format name="PNGQ_FAST" type ="PNG">
>>>      <compression>fast</compression>  <!-- fast or best -->
>>>      <colors>256</colors>
>>>   </format>
>>>   <format name="myjpeg" type ="JPEG">
>>>      <quality>75</quality>
>>>   </format>
>>>   <format name="PNG_BEST" type ="PNG">
>>>      <compression>best</compression>
>>>   </format>
>>>   <format name="mixed" type="MIXED">
>>>      <transparent>PNG_BEST</transparent>
>>>      <opaque>JPEG</opaque>
>>>   </format>
>>>   <source name="ms_wms" type="wms">
>>>      <getmap>
>>>         <params>
>>>            <FORMAT>image/png</FORMAT>
>>>            <LAYERS>YORK2009</LAYERS>
>>>            <TRANSPARENT>true</TRANSPARENT>
>>>         </params>
>>>      </getmap>
>>>      <http>
>>>         <url>http://localhost.jdbarnes.com/cgi-bin/ms_wms</url>
>>>      </http>
>>>   </source>
>>>   <tileset name="ms_tileset_8">
>>>      <source>ms_wms</source>
>>>      <cache>disk</cache>
>>>      <!--grid restricted_extent="-79.8205259 43.7179074 -79.1161194
>>> 44.4110187">WGS84</grid-->
>>>      <grid>googlemaps_grid</grid>
>>>      <format>mixed</format>
>>>      <metatile>8 8</metatile>
>>>      <metabuffer>0</metabuffer>
>>>   </tileset>
>>>   <default_format>JPEG</default_format>
>>>   <service type="wmts" enabled="true"/>
>>>   <service type="tms" enabled="true"/>
>>>   <service type="kml" enabled="true"/>
>>>   <service type="gmaps" enabled="true"/>
>>>   <service type="ve" enabled="true"/>
>>>   <service type="demo" enabled="true"/>
>>>   <errors>report</errors>
>>>   <lock_dir>/var/mod-geocache/caches</lock_dir>
>>> </geocache>
>>> On 6 October 2011 10:31, thomas bonfort<thomas.bonfort at gmail.com>  wrote:
>>>> what seed command were you using, and what kind of cache ?
>>>> On Thu, Oct 6, 2011 at 15:52, Travis Kirstine<traviskirstine at gmail.com>
>>>>  wrote:
>>>>> Thanks Thomas,
>>>>> The complete error message is below.  Do you have any idea what would
>>>>> cause this error - why would mapcache fail to create or delete the
>>>>> lockfile.
>>>>> seeding tile 583296 1337304 21failed to remove lockfile
>>>>> /var/mod-geocache/cachesseeding tile 583304 1337296 21failed to remove
>>>>> lockfile
>>>>> /var/mod-geocache/caches/_gc_lock-21-167156-72919-ms_tileset_8:
>>>>> No such file or directoryfailed to remove lockfile
>>>>> /var/mod-geocache/caches/_gc_lock-21-167157-72919-ms_tileset_8: No
>>>>> /var/mod-geocache/caches/_gc_lock-20-83579-36459-ms_tileset_8: No such
>>>>> /var/mod-geocache/caches/_gc_lock-21-167156-72918-ms_tileset_8: No
>>>>> /var/mod-geocache/caches/_gc_lock-21-167159-72918-ms_tileset_8: No
>>>>> /var/mod-geocache/caches/_gc_lock-21-167158-72918-ms_tileset_8: No
>>>>> /var/mod-geocache/caches/_gc_lock-21-167159-72919-ms_tileset_8: No
>>>>> /var/mod-geocache/caches/_gc_lock-18-20895-9114-ms_tileset_8: No such
>>>>> /var/mod-geocache/caches/_gc_lock-21-167158-72919-ms_tileset_8: No
>>>>> Regards
>>>>> On 6 October 2011 09:11, thomas bonfort<thomas.bonfort at gmail.com>
>>>>>  wrote:
>>>>>> The log message should be more explicit, and contain the reason of the
>>>>>> unsuccessful removal. In any case, looking at the code, this error
>>>>>> will have interrupted the seeding process.
>>>>>> regards,
>>>>>> thomas
>>>>>> On Thu, Oct 6, 2011 at 15:03, Travis
>>>>>> Kirstine<traviskirstine at gmail.com>  wrote:
>>>>>>> Hi All,
>>>>>>> I hope this is the right spot to post MapCache questions.  I had
>>>>>>> seeded a large area and receive the error "failed to remove
>>>>>>> lockfile".
>>>>>>>  It appears that this error(s) happens at the end of the seeding but
>>>>>>> it is hard tell as the process has been running for a few days.  Does
>>>>>>> this error kill the seeder process or is it simply a warning?
>>>>>>> Regards
>>>>>>> _______________________________________________
>>>>>>> mapserver-users mailing list
>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
