[mapserver-users] tiled geotiff map service for openlayers
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Oct 14 08:21:53 EDT 2011
Hello,
My quick thoughts:
- execute gdalinfo (http://www.gdal.org/gdalinfo.html) on your tif file
- use the extents returned from gdalinfo in your EXTENT parameter in
your mapfile
- remove projection info from your mapfile
- make sure your UNITS in your mapfile match the extent value
- test your mapfile with the shp2img commandline utility
(http://www.mapserver.org/utilities/shp2img.html)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-10-14 8:56 AM, Doğukan ATALAY wrote:
> i have a geo tiff file, generated it with arcmap, im sure it s working
> well because tried it with quantumgis, it opened geo tiff,
> i want to use tiff file with mapserver, so i installed cgi-mapserver on
> ubuntu linux,
> ubuntu:/var/www$ /usr/lib/cgi-bin/mapserv -v
> MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> it supports tiff,
> the problem is i can t see my map:) i see only blank white area, (
> http://imageshack.us/photo/my-images/198/screenshot2raw.png/ )
> i want to create tales and serve it for open layers application, if you
> help, i will be happy, thank you
> ubuntu:/var/www/data$ ls
> Deneme.tfw Deneme.tif Deneme.tif.aux.xml Deneme.tif.ovr
> *map file content:*
> MAP
> NAME parcels_map
> STATUS ON
> SIZE 5000 7000
> EXTENT 489885 5450946 490904 5451637
> UNITS METERS
> IMAGECOLOR 255 255 255
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> END
> WEB
> TEMPLATE "template2.html"
> IMAGEPATH "/var/www/tmp/"
> IMAGEURL "tmp/"
> END
> LAYER
> NAME "Deneme"
> * DATA "data/Deneme.tif"*
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> "lat_2=46"
> "lat_1=46.29"
> "lat_0=46.29"
> "lon_0=18.11"
> "datum=WGS84"
> END
> TYPE RASTER
> STATUS ON
> END
> END
