[mapserver-users] MapCache - failed to remove lockfile error
Travis Kirstine traviskirstine at gmail.com
Fri Oct 14 08:42:07 EDT 2011
Thomas,
The latest version (as of last week) seems to have fixed the lockfile
issue.  We are running into issues with the linking of transparent
tiles:
failed to link tile
/home/caches/0837DURH_cache/googlemaps_grid/21/000/590/400/001/333/608.xxx
to /home/caches/0837DURH_cache/googlemaps_grid/blanks/00000000.xxx: No
such file or directory
We are running the seeder with 24 threads (all cores on the server).
Could there be a issue with linking to the same file simultaneously?
Regards
On 7 October 2011 09:41, Travis Kirstine <traviskirstine at gmail.com> wrote:
> We checked out a version of mod-geocache on sept 22, my guess is that
> it is version 0.4x.  We will check out the latest mapcache version
> from the mapserver trunk.
> Regards
> On 7 October 2011 06:16, thomas bonfort <thomas.bonfort at gmail.com> wrote:
>> What version of mod-geocache are you using (revision number or release
>> version) ?
>> On Thu, Oct 6, 2011 at 22:17, Travis Kirstine <traviskirstine at gmail.com> wrote:
>>> This doesn't seem to be a issue, I have lots of inodes left.  It
>>> appears that the error occurred when generating (linking)  areas with
>>> a large volume of transparent tiles, could this be related?
>>> Regards
>>> On 6 October 2011 14:19, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>>>> Have you verified that you have not filled up the disk or run out of inodes?
>>>> # check the diskspace with
>>>> df -h
>>>> # check for inode issues
>>>> touch /path/to/cache/test.junk
>>>> # if the touch failed then you have run out of inodes
>>>> # otherwise clean up
>>>> rm /path/to/cache/test.junk
>>>> Thanks,
>>>>  -Steve W
>>>> On 10/6/2011 12:14 PM, thomas bonfort wrote:
>>>>> I don't have a specific advice to give unfortunately. There have been
>>>>> some fixes lately (macpcache only, not mod-geocache) to the way
>>>>> multiple threads accessed the curl library that might help, so you
>>>>> might want to try with a fresh checkout from the mapserver svn.
>>>>> thomas
>>>>> On Thu, Oct 6, 2011 at 18:08, Travis Kirstine<traviskirstine at gmail.com>
>>>>>  wrote:
>>>>>> Thomas,
>>>>>> My command is below, I'm using a disk cache, my config file is below.
>>>>>> I'm using a local copy of MapServer for the source image generation
>>>>>> ./geocache_seed -c ../geocache.xml -t ms_tileset_8 -z 0,21 -e
>>>>>> -8895580.772,5411569.158,-8797157.196,5538966.276 -n 6
>>>>>> <?xml version="1.0" encoding="UTF-8"?>
>>>>>> <geocache>
>>>>>>   <metadata>
>>>>>>      <title>geocache service esx11</title>
>>>>>>      <abstract>mod-geocache service</abstract>
>>>>>>      <!-- url>http://mysuperhost/proxy/to/geocache</url -->
>>>>>>   </metadata>
>>>>>>         <grid name="googlemaps_grid">
>>>>>>            <metadata>
>>>>>>               <title>GoogleMapsCompatible</title>
>>>>>> <WellKnownScaleSet>urn:ogc:def:wkss:OGC:1.0:GoogleMapsCompatible</WellKnownScaleSet>
>>>>>>            </metadata>
>>>>>>            <extent>-20037508.3427892480 -20037508.3427892480
>>>>>> 20037508.3427892480 20037508.3427892480</extent>
>>>>>>            <srs>EPSG:3857</srs>
>>>>>>            <srsalias>EPSG:900913</srsalias>
>>>>>>            <units>m</units>
>>>>>>            <size>256 256</size>
>>>>>>            <resolutions>156543.0339280410 78271.51696402048
>>>>>> 39135.75848201023 19567.87924100512 9783.939620502561
>>>>>> 4891.969810251280 2445.984905125640 1222.992452562820
>>>>>> 611.4962262814100 305.7481131407048 152.8740565703525
>>>>>> 76.43702828517624 38.21851414258813 19.10925707129406
>>>>>> 9.554628535647032 4.777314267823516 2.388657133911758
>>>>>> 1.194328566955879 0.5971642834779395 0.29858214173896975
>>>>>> 0.149291070869484875 0.0746455354347424375</resolutions>
>>>>>>         </grid>
>>>>>>   <cache name="disk" type="disk">
>>>>>>      <base>/var/mod-geocache/caches</base>
>>>>>>      <symlink_blank/>
>>>>>>   </cache>
>>>>>>   <format name="PNGQ_FAST" type ="PNG">
>>>>>>      <compression>fast</compression>  <!-- fast or best -->
>>>>>>      <colors>256</colors>
>>>>>>   </format>
>>>>>>   <format name="myjpeg" type ="JPEG">
>>>>>>      <quality>75</quality>
>>>>>>   </format>
>>>>>>   <format name="PNG_BEST" type ="PNG">
>>>>>>      <compression>best</compression>
>>>>>>   </format>
>>>>>>   <format name="mixed" type="MIXED">
>>>>>>      <transparent>PNG_BEST</transparent>
>>>>>>      <opaque>JPEG</opaque>
>>>>>>   </format>
>>>>>>   <source name="ms_wms" type="wms">
>>>>>>      <getmap>
>>>>>>         <params>
>>>>>>            <FORMAT>image/png</FORMAT>
>>>>>>            <LAYERS>YORK2009</LAYERS>
>>>>>>            <TRANSPARENT>true</TRANSPARENT>
>>>>>>         </params>
>>>>>>      </getmap>
>>>>>>      <http>
>>>>>>         <url>http://localhost.jdbarnes.com/cgi-bin/ms_wms</url>
>>>>>>      </http>
>>>>>>   </source>
>>>>>>   <tileset name="ms_tileset_8">
>>>>>>      <source>ms_wms</source>
>>>>>>      <cache>disk</cache>
>>>>>>      <!--grid restricted_extent="-79.8205259 43.7179074 -79.1161194
>>>>>> 44.4110187">WGS84</grid-->
>>>>>>      <grid>googlemaps_grid</grid>
>>>>>>      <format>mixed</format>
>>>>>>      <metatile>8 8</metatile>
>>>>>>      <metabuffer>0</metabuffer>
>>>>>>   </tileset>
>>>>>>   <default_format>JPEG</default_format>
>>>>>>   <service type="wmts" enabled="true"/>
>>>>>>   <service type="tms" enabled="true"/>
>>>>>>   <service type="kml" enabled="true"/>
>>>>>>   <service type="gmaps" enabled="true"/>
>>>>>>   <service type="ve" enabled="true"/>
>>>>>>   <service type="demo" enabled="true"/>
>>>>>>   <errors>report</errors>
>>>>>>   <lock_dir>/var/mod-geocache/caches</lock_dir>
>>>>>> </geocache>
>>>>>> On 6 October 2011 10:31, thomas bonfort<thomas.bonfort at gmail.com>  wrote:
>>>>>>> what seed command were you using, and what kind of cache ?
>>>>>>> On Thu, Oct 6, 2011 at 15:52, Travis Kirstine<traviskirstine at gmail.com>
>>>>>>>  wrote:
>>>>>>>> Thanks Thomas,
>>>>>>>> The complete error message is below.  Do you have any idea what would
>>>>>>>> cause this error - why would mapcache fail to create or delete the
>>>>>>>> lockfile.
>>>>>>>> seeding tile 583296 1337304 21failed to remove lockfile
>>>>>>>> /var/mod-geocache/cachesseeding tile 583304 1337296 21failed to remove
>>>>>>>> lockfile
>>>>>>>> /var/mod-geocache/caches/_gc_lock-21-167156-72919-ms_tileset_8:
>>>>>>>> No such file or directoryfailed to remove lockfile
>>>>>>>> /var/mod-geocache/caches/_gc_lock-21-167157-72919-ms_tileset_8: No
>>>>>>>> /var/mod-geocache/caches/_gc_lock-20-83579-36459-ms_tileset_8: No such
>>>>>>>> /var/mod-geocache/caches/_gc_lock-21-167156-72918-ms_tileset_8: No
>>>>>>>> /var/mod-geocache/caches/_gc_lock-21-167159-72918-ms_tileset_8: No
>>>>>>>> /var/mod-geocache/caches/_gc_lock-21-167158-72918-ms_tileset_8: No
>>>>>>>> /var/mod-geocache/caches/_gc_lock-21-167159-72919-ms_tileset_8: No
>>>>>>>> /var/mod-geocache/caches/_gc_lock-18-20895-9114-ms_tileset_8: No such
>>>>>>>> /var/mod-geocache/caches/_gc_lock-21-167158-72919-ms_tileset_8: No
>>>>>>>> Regards
>>>>>>>> On 6 October 2011 09:11, thomas bonfort<thomas.bonfort at gmail.com>
>>>>>>>>  wrote:
>>>>>>>>> The log message should be more explicit, and contain the reason of the
>>>>>>>>> unsuccessful removal. In any case, looking at the code, this error
>>>>>>>>> will have interrupted the seeding process.
>>>>>>>>> regards,
>>>>>>>>> thomas
>>>>>>>>> On Thu, Oct 6, 2011 at 15:03, Travis
>>>>>>>>> Kirstine<traviskirstine at gmail.com>  wrote:
>>>>>>>>>> Hi All,
>>>>>>>>>> I hope this is the right spot to post MapCache questions.  I had
>>>>>>>>>> seeded a large area and receive the error "failed to remove
>>>>>>>>>> lockfile".
>>>>>>>>>>  It appears that this error(s) happens at the end of the seeding but
>>>>>>>>>> it is hard tell as the process has been running for a few days.  Does
>>>>>>>>>> this error kill the seeder process or is it simply a warning?
>>>>>>>>>> Regards
>>>>>>>>>> _______________________________________________
>>>>>>>>>> mapserver-users mailing list
>>>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
