[mapserver-users] Problem compiling MapServer - "error: cannot
find gif lib"
thomas bonfort
thomas.bonfort at gmail.com
Mon Oct 17 08:18:01 EDT 2011
maybe you didn't compile gdal with --with-ogr ?
thomas
On Mon, Oct 17, 2011 at 12:44, David Quinn <daithiquinn at gmail.com> wrote:
> Hi Thomas,
> Thanks - that helped me fix the problem. I used the following options:
> ./configure --prefix=$HOME \
> --enable-debug \
> --with-gd \
> --with-freetype --without-tiff \
> --with-gdal=/home/david/bin/gdal-config \
> --with-ogr=/home/david/bin/gdal-config \
> --with-proj=/home/david/src/proj-4.7.0/ \
> --without-pdf \
> --with-png=/usr/ --with-threads \
> --with-postgis=/home/david/bin/pg_config \
> --with-wfs --with-wcs --with-wmsclient --with-wfsclient \
> --with-php=$HOME --enable-debug \
> --with-geos=/home/david/bin/geos-config \
> --with-python \
> --with-gif=$HOME
> and received the following summary:
> MapServer is now configured for
> -------------- Compiler Info -------------
> C compiler: gcc -g -fPIC -Wall
> C++ compiler: g++ -g -fPIC -Wall
> Debug: -g
> Generic NINT:
> -------------- Renderer Settings ---------
> OpenGL support:
> zlib support: -DUSE_ZLIB
> png support: -DUSE_PNG
> gif support: -DUSE_GIF
> jpeg support: -DUSE_JPEG
> freetype support: -DUSE_FREETYPE
> iconv support: -DUSE_ICONV
> AGG support: internal
> SVG Symbol support: -DUSE_AGG_SVG_SYMBOLS
> Cairo (SVG,PDF) support:
> KML support:
> -------------- Support Libraries ---------
> Proj.4 support: -DUSE_PROJ
> Libxml2 support: -DUSE_LIBXML2
> FriBidi support:
> Curl support: -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH
> FastCGI support:
> Threading support: -DUSE_THREAD
> GEOS support: -DUSE_GEOS
> XML Mapfile support:
> XSLT support:
> EXSLT support:
> -------------- Data Format Drivers -------
> PostGIS support: -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION
> ArcSDE support:
> OGR support: -DUSE_OGR
> GDAL support: -DUSE_GDAL
> Oracle Spatial support:
> -------------- OGC Services --------------
> WMS Server: -DUSE_WMS_SVR
> WMS Client: -DUSE_WMS_LYR
> WFS Server: -DUSE_WFS_SVR
> WFS Client: -DUSE_WFS_LYR
> WCS Server: -DUSE_WCS_SVR
> SOS Server:
> -------------- MapScript -----------------
> PHP MapScript: yes
> However I ran into problems when I ran 'make'.
> gcc -c -g -fPIC -Wall -DHAVE_VSNPRINTF -DNEED_STRLCPY -DNEED_STRLCAT
> -DNEED_STRRSTR -DUSE_WMS_LYR -DUSE_WFS_LYR -DUSE_LIBXML2
> -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH -DUSE_WCS_SVR -DUSE_WFS_SVR
> -DUSE_WMS_SVR -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION -DUSE_GDAL
> -DUSE_OGR -DUSE_GEOS -DUSE_THREAD -DUSE_PROJ -DUSE_AGG_SVG_SYMBOLS
> -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS
> -DGD_HAS_GET_TRUE_COLOR_PIXEL -DUSE_ICONV -DUSE_GIF -DUSE_PNG -DUSE_ZLIB
> -DUSE_FREETYPE -DDISABLE_CVSID -I/usr/include/freetype2 -I/usr//include
> -I/home/david/include -I/usr/include -Irenderers/agg/include
> -I/home/david/src/proj-4.7.0//src -I/home/david/include
> -I/home/david/include -I/home/david/include -I/usr/include/libxml2
> shp2img.c -o shp2img.o
> g++ -g -fPIC -Wall -DHAVE_VSNPRINTF -DNEED_STRLCPY -DNEED_STRLCAT
> shp2img.o -L. -lmapserver -lfreetype -lgd -L/usr/lib -lgd -ljpeg -lfreetype
> -L/usr//lib -lpng -lz -lXpm -lX11 -lexpat
> -L/home/david/src/proj-4.7.0//src/.libs -lproj -ljpeg -L/usr//lib -lpng
> -L/home/david/lib -lgif -L/home/david/lib -lgdal -L/home/david/lib -lpq
> -L/usr/kerberos/lib -lcurl -ldl -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err
> -lidn -lssl -lcrypto -lz -L/home/david/lib -lgeos_c -lpthread -lc -lz
> -L/usr/lib -lxml2 -lz -lm -lm -lstdc++ -o shp2img
> ./libmapserver.a(mapogroutput.o): In function `msOGRWriteShape':
> /home/david/src/mapserver-6.0.1/mapogroutput.c:380: undefined reference to
> `OGR_G_ForceToPolygon'
> /home/david/src/mapserver-6.0.1/mapogroutput.c:385: undefined reference to
> `OGR_G_ForceToMultiPolygon'
> /home/david/src/mapserver-6.0.1/mapogroutput.c:390: undefined reference to
> `OGR_G_ForceToMultiPoint'
> /home/david/src/mapserver-6.0.1/mapogroutput.c:395: undefined reference to
> `OGR_G_ForceToMultiLineString'
> ./libmapserver.a(mapogroutput.o): In function `msOGRWriteFromQuery':
> /home/david/src/mapserver-6.0.1/mapogroutput.c:979: undefined reference to
> `CPLCreateZip'
> /home/david/src/mapserver-6.0.1/mapogroutput.c:984: undefined reference to
> `CPLCreateFileInZip'
> /home/david/src/mapserver-6.0.1/mapogroutput.c:989: undefined reference to
> `CPLCloseZip'
> /home/david/src/mapserver-6.0.1/mapogroutput.c:1000: undefined reference to
> `CPLWriteFileInZip'
> /home/david/src/mapserver-6.0.1/mapogroutput.c:1004: undefined reference to
> `CPLCloseFileInZip'
> /home/david/src/mapserver-6.0.1/mapogroutput.c:1006: undefined reference to
> `CPLCloseZip'
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
> Does anyone have a suggestion about how I can solve the following errors? I
> read some very old bug reports with the following error suggesting that it
> was due to the compiler version but I don't know if this is relevant.
> Thanks,
> David
> On Mon, Oct 17, 2011 at 3:17 AM, thomas bonfort <thomas.bonfort at gmail.com>
> wrote:
>> --with-gif=$HOME if you have installed it there. As a rule of thumb,
>> it is not a good idea to only compile the packages and not install
>> them (i.e. no make install) as there is no reason that the packages
>> respect the include/ lib/ hierarchy inside their source structure.
>> (i.e. you should be using --with-gdal=/home/david/bin/gdal-config,
>> --with-proj=/home/david, etc... )
>> thomas
>> On Mon, Oct 17, 2011 at 06:48, David Quinn <daithiquinn at gmail.com> wrote:
>> > Hello List,
>> > I'm trying to install Mapserver on CentOS5 (specifically on a Webfaction
>> > shared hosting server). I'm using the following options:
>> > --enable-debug \
>> > --with-gd \
>> > --with-gdal=/home/david/src/gdal-1.8.1/apps/gdal-config \
>> > --with-ogr=/home/david/src/gdal-1.8.1/apps/gdal-config \
>> > --without-pdf \
>> > --with-postgis=/home/david/src/postgresql-8.4.6/src/bin/pg_config \
>> > --with-php=/usr/include/php5/ --enable-debug \
>> > --with-python \
>> > --with-gif=/home/david/src/giflib-4.1.6/lib/gif_lib.h
>> > However I get the following error:
>> > checking setjmp.h usability... yes
>> > checking setjmp.h presence... yes
>> > checking for setjmp.h... yes
>> > configure: checking where GIF is installed...
>> > configure: error: cannot find gif lib in
>> > /home/urbmet/src/giflib-4.1.6/lib/gif_lib.h
>> > After I got this error the first time, I installed giflib-4.1.6. The
>> > results
>> > of running $ find | grep gif_lib.h
>> > ./include/gif_lib.h
>> > ./src/giflib-4.1.6/lib/gif_lib.h
>> > ./src/giflib-4.1.6/doc/gif_lib.html
>> > ./src/gdal-1.8.1/frmts/gif/giflib/gif_lib.h
>> > I have tried --with-gif with all of the following arguments, either to
>> > the
>> > folder or to gif_lib.h without success. Am I missing any settings or
>> > dependencies?
>> > Thanks,
>> > David
>> > _______________________________________________
>> > mapserver-users mailing list
>> > mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
