[mapserver-users] problem with Regular Expression
Travis Kirstine traviskirstine at gmail.com
Mon Oct 17 09:49:52 EDT 2011
Marc-André
I have never used regex in MS but this should work:
EXPRESSION ('[res_co_reg]' ~* '^.*RES_CO_REG.*$')
I believe that regex are costly in term of performance
Regards
On 17 October 2011 09:26, Marc-André Trottier
<trottier.marcandre at gmail.com> wrote:
> hi!
> i'm using Mapserver 6.0 and got this error :
> msValidateParameter(): Regular expression error. Parameter pattern
> validation failed.
> with this CLASS :
>  CLASS
>     NAME "Région administrative"
>     EXPRESSION  ('[res_co_reg]' eq '%RES_CO_REG%')
>     GROUP "adn"
>     LABEL
>         COLOR 139 35 35
>         ANTIALIAS FALSE
>         TYPE TRUETYPE
>         FONT "verait"
>         SIZE 12
>         POSITION AUTO
>         FORCE FALSE
>         MINDISTANCE 10000
>         PARTIALS FALSE
>         BUFFER 3
>     END
>     STYLE
>         OUTLINECOLOR 139 35 35
>         WIDTH 5
>     END
> END
> but everything works well
> i also tried and the error always appear :
>     EXPRESSION  ("[res_co_reg]" eq "%RES_CO_REG%")
>     EXPRESSION  ('[res_co_reg]' = '%RES_CO_REG%')
>     EXPRESSION  ([res_co_reg] eq %RES_CO_REG%)
>     EXPRESSION  ("[res_co_reg]" = "%RES_CO_REG%")
> mapserver-users at lists.osgeo.org
