[mapserver-users] Re: Mapserver Projection Errors
SixDegrees paulcarlisle at comcast.net
Thu Oct 20 05:17:44 EDT 2011
I can try an example without that parameter, but the layers are machine
generated and use a GDAL function to extract the Proj.4 string from the
image file, so I don't have much control over their format. Although it
probably wouldn't be difficult to extract a single argument if that's the
cause of the problem. In any case, I'll give it a whirl when I return
tomorrow.
Ben Madin wrote:
> Paul,
> is the +towgs necessary here?
> couldn't it just be :
> +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
> (this is taken from http://spatialreference.org/ref/epsg/4326/)
> cheers
> Ben
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapserver-Projection-Errors-tp6908527p6912186.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
