AW: [mapserver-users] Mapserver Projection Errors
SixDegrees paulcarlisle at comcast.net
Thu Oct 20 06:00:37 EDT 2011
Is this example correct? This is a cut-and-paste of what is generated by our
code, as are the other examples shown earlier:
   PROJECTION
      "+proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +no_defs"
   END
Should each argument have a '+' in front of it, or only the first? Note that
I'm already trimming excess whitespace off the strings; gdal seems to add a
space at the end of the string.
Eichner, Andreas - SID-NLK wrote:
> If you auto-generate the map files and spurious errors occur it might be
> a bug in your script generating the projection strings. I personally
> prefer the one-liners but they need to be trimmed and the first
> character should be "+". You should find a generated map file that
> triggers the error and check it's generated PROJECTION blocks. With a
> leading space mapserver probably tries to handle it as an old style
> comma separated init string like "proj=utm,zone=11,ellps=WGS84". Once
> again: projection strings should be build with care!
> mapserver-users at .osgeo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapserver-Projection-Errors-tp6908527p6912316.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
