[mapserver-users] map rotation, extent & a border
Shorthouse, David
dshorthouse at eol.org
Thu Oct 20 09:07:44 EDT 2011
Folks,
Been trying to solve this one and cannot figure it out. Attached is my
attempt to put a border around the outside edge of a map using
PHP-mapscript. If the map is not rotated, it's easy to use the map's
extent to draw such a border by creating a layer specifically for this
purpose. However, when a map is rotated, one can no longer use the
map's extent like this because the four extent coordinates are not
similarly rotated. My question is, how do a I make a border around the
outside edge of a map when the map is rotated? Is there a method to
learn what are the actual extent coordinates post-rotate?
Thanks,
David P. Shorthouse
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111020/2750389d/Rotated-1-0001.png
