[mapserver-users] Re: Drawing different lengths of arrows
knasia knasia at poczta.fm
Mon Oct 24 13:44:53 EDT 2011
You were right, the first idea brought some results, but I have a problem
which I cannot solve.
I have splited my line using PostGIS and got a expected results from select.
Now, when I put it to mapserver it doesn't work as I wish
a)What I want to display is:
DATA 'geom_path FROM (SELECT line_substring( e.geom_path,
*(1-(e.veh_quantity)*7/(e.road_length))*, 1) as geom_path, e.veh_quantity as
quantity FROM edges   e  JOIN 	nodes n  ON EndPoint(e.geom_path)=n.coor
WHERE 	 e.node1_id=n.id  )  as subquery using unique id using srid=4326 '
and it doesn't work properly
b) When I put instead of (1-(e.veh_quantity)*7/(e.road_length)) some special
numbers which come from my select it works good. For example:
DATA 'geom_path FROM (SELECT line_substring( reverse(e.geom_path), *0.2*, 1)
as geom_path, e.veh_quantity as  quantity FROM edges   e  JOIN 	nodes n  ON
EndPoint(e.geom_path)=n.coor WHERE 	 e.node1_id=n.id  )  as subquery using
I have no idea how to solve it.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Drawing-different-lengths-of-arrows-tp6922584p6925957.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
