[mapserver-users] Sporadically "Cannot create OCI handlers"
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Oct 25 08:13:29 EDT 2011
Make sure to verify your connection string (to any database) first
through an ogrinfo command, then once that returns properly focus on
your mapfile.
If I run into problems with the connection string/query in ogrinfo, then
I usually focus on the database, testing with psql (Postgres) or sqlplus
(Oracle) commandline utilities...then again once the connection/query is
established there then I move to ogrinfo, then to the mapfile (with
shp2img).
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-10-25 9:00 AM, Meine Toonen wrote:
> Hi list,
> I have a layer defined in a mapfile, using an oracle connection. Most of
> the time this works, but sometimes I get an error.
> The Error:
> msDrawMap(): Image handling error. Failed to draw layer named
> 'telvakken_l'.; msOracleSpatialLayerOpen(): OracleSpatial error. Cannot
> create OCI Handlers. Connection failed. Check the connection string.
> Seems to me the connection string is fine, because it does work. Maybe
> you can help me? The layer is defined below:
> The Mapfile:
> LAYER
> NAME "telvakken_l"
> DATA "SHAPE from (select OBJECTID,TELPUNT,NAAM_WEGVA,BEHEERDER,BEGIN_HMP,EIND_HMP,WEGN,SHAPE from telvakken_l) using UNIQUE OBJECTID SRID 90112"
> TYPE LINE
> CONNECTIONTYPE oraclespatial
> CONNECTION "UN/PW at DB"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> METADATA
> ows_title "Verkeerstelvakken"
> ows_extent "150000 296000 223454 435000"
> ows_abstract "Verkeerstelvakken"
> gml_include_items "all"
> gml_featureid "OBJECTID"
> ows_metadataurl_format "text/xml"
> ows_metadataurl_href "http://acceptatie.prvlimburg.nl/mapfiles/infrastructuur/metadata/telvakken_l.xml"
> ows_metadataurl_type "FGDC"
> END #METADATA
> DUMP TRUE
> OPACITY 85
> STATUS on
> UNITS METERS
> TEMPLATE "/var/www/html/blank.html"
> SIZEUNITS PIXELS
> MINSCALEDENOM 0
> MAXSCALEDENOM 10000000
> TOLERANCE 3
> TOLERANCEUNITS PIXELS
> PROJECTION
> "init=epsg:28992"
> END #PROJECTION
> CLASS
> NAME 'Verkeerstelvakken'
> STYLE
> WIDTH 2
> COLOR 255 31 0
> END #STYLE
> END #CLASS
> END #LAYER
> Thanks in advance.
> Kind regards,
> Meine Toonen
> B3Partners BV
> Tel: 030 214 2083
