AW: [mapserver-users] Sporadically "Cannot create OCI handlers"
Meine Toonen meinetoonen at b3partners.nl
Wed Oct 26 04:16:47 EDT 2011
Thanks for the reactions!
@Andreas: I tried without close_connection=defer, and the error doesn't occur anymore. So it seems like it is solved, but as you said, kinda hard to debug. The mapserver version is 5.6.3 and it supports fastcgi.
@Jeff: Will ask the maintainer of the mapserver/database to use the commandline tools to check the querystring. Thanks for the suggestions.
With kind regards,
Meine Toonen
B3Partners BV
Tel: 030 214 2083
  _____
From: Eichner, Andreas - SID-NLKM [mailto:Andreas.Eichner at sid.sachsen.de]
To: Meine Toonen [mailto:meinetoonen at b3partners.nl], mapserver-users at lists.osgeo.org
Sent: Wed, 26 Oct 2011 09:58:03 +0200
Subject: AW: [mapserver-users] Sporadically "Cannot create OCI handlers"
  How do you use MapServer, do you use FastCGI? And which version? I had
  the same problem and I believe with v6.0.1 it doesn't happen anymore. I
  guess it happens when a connection handle isn't used for some time, the
  database server already closed it and MS picks it up but doesn't handle
  the error properly.
  But this is only a guess and happens so rarely that it's really hard to
  debug. How often does it occur on your site? Are you able to try without
  CLOSE_CONNECTION=DEFER?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111026/7d935a03/attachment.html
