[mapserver-users] IIS and mapfiles and also GDAL
Brent Fraser bfraser at geoanalytic.com
Fri Sep 2 11:28:01 EDT 2011
Chris,
   If you have a current version of Mapserver (v5,v6?), then should be
GDAL compiled in.  The GDAL library needs to find projection definition
files so I usually include the following in all my map files:
     CONFIG "PROJ_LIB" "\ms4w\proj\nad"
     CONFIG "GDAL_DATA" "\ms4w\gdaldata"
Another potential problem you may be having  is with EPSG:900913.  It is
not included in GDAL/PROJ's epsg file so I add the following to
\ms4w\proj\nad\epsg:
<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
+x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs <>
Best Regards,
Brent Fraser
On 9/2/2011 9:16 AM, Chris Jackson wrote:
> Hi Brent
> Thanks for the quick answers, the new rewriting rules (with reverse
> proxy) have worked well with Tomcat on port 8080 - no more isapi
> dlls!  What you listed for Mapnik is essentially like mine, what I am
> not sure is what other GDAL configuration is needed on the box - just
> an environment variable or some other setting in the mapfile...?
> Thanks
> Chris
> On 2 September 2011 16:04, Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
>     Chris,
>       I've used the Iconic Rewriter with older versions of IIS (the
>     native rewriting capability in IIS7 looks interesting).  You may
>     be able to use an environment variable to set the default map
>     file, but this may not be very useful if you have multiple map
>     files.  There are a few other options for hiding the mapfile
>     (proxy script, redirect, form post instead of get, etc), put I
>     think the rewrite method is the most effective (the client never
>     gets the map file path), with almost no performance hit.
>       The way I access Mapnik tiles in mapserver is to create a layer
>     in the map file:
>     LAYER
>         DATA "frmt_wms_openstreetmap_MAPNIK.xml"
>         NAME "Mapnik"
>         PROJECTION
>           "proj=merc" "a=6378137" "b=6378137" "lat_ts=0.0" "lon_0=0.0"
>     "x_0=0.0" "y_0=0" "k=1.0" "units=m" "nadgrids=@null" "no_defs"
>         END
>         STATUS ON
>         TYPE RASTER
>         PROCESSING "OVERSAMPLE_RATIO=1"
>         PROCESSING "LOAD_FULL_RES_IMAGE=NO"
>         UNITS METERS
>     END # LAYER
>     and frmt_wms_openstreetmap_MAPNIK.xml XML file of
>     <GDAL_WMS>
>     <Service name="TMS">
>     <ServerUrl>http://tile.openstreetmap.org/${z}/${x}/${y}.png</ServerUrl>
>     </Service>
>     <DataWindow>
>     <UpperLeftX>-20037508.34</UpperLeftX>
>     <UpperLeftY>20037508.34</UpperLeftY>
>     <LowerRightX>20037508.34</LowerRightX>
>     <LowerRightY>-20037508.34</LowerRightY>
>     <TileLevel>19</TileLevel>
>     <TileCountX>1</TileCountX>
>     <TileCountY>1</TileCountY>
>     <YOrigin>top</YOrigin>
>     </DataWindow>
>     <Projection>EPSG:900913</Projection>
>     <BlockSizeX>256</BlockSizeX>
>     <BlockSizeY>256</BlockSizeY>
>     <BandsCount>3</BandsCount>
>     <Cache />
>     </GDAL_WMS>
>     Best Regards,
>     Brent Fraser
>     On 9/2/2011 8:13 AM, Chris Jackson wrote:
>>     Hi
>>     I just wanted to check if the only way to parse a mapfile in an
>>     IIS environment to use an absolute path to the mapfiles e.g.
>>     http://myserver/cgi-bin/mapserv.exe?map=C:\Inetpub\wwwroot\workshop\itasca.map.
>>     I wonder if anyone has had success with rewrite rules (IIS7)?
>>     Also how is GDAL triggered when calling the mapfile (in IIS).
>>     The scenario is I am trying to use an xml in the mapfile layer
>>     which then calls http://tile.openstreetmap.org/
>>     The XML is
>>     <GDAL_WMS>
>>     <http://tile.openstreetmap.org/$%7Bz%7D/$%7Bx%7D/$%7By%7D.png></ServerUrl>
>>     </Service>
>>     <DataWindow>
>>     </DataWindow>
>>     <Cache/>
>>     </GDAL_WMS>
>>     Am I remotely doing this the right way?  I am used to calling
>>     local data from the mapfile and tiled services is a bit of a new
>>     beast, so I thought I would give it a go!
>>     Many thanks in advance
>>     Chris
>>     _______________________________________________
>>     mapserver-users mailing list
>>     mapserver-users at lists.osgeo.org  <mailto:mapserver-users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110902/03970be0/attachment-0001.html
