[mapserver-users] Problem compiling MapServer 6.0.1 with libpng
Dejan Gambin dejan.gambin at coin.hr
Thu Sep 8 06:12:24 EDT 2011
After many trials and missings, I am still unable to compile MapServer 6.0.1 (6.0.0 also) on my Debian Lenny machine.
Here is the error I get:
./libmapserver.a(mapimageio.o): In function `savePalettePNG':
/home/dgambin/mapserver-6.0.1/mapimageio.c:274: undefined reference to `png_set_longjmp_fn'
./libmapserver.a(mapimageio.o): In function `saveAsPNG':
/home/dgambin/mapserver-6.0.1/mapimageio.c:461: undefined reference to `png_set_longjmp_fn'
./libmapserver.a(mapimageio.o): In function `readPNG':
/home/dgambin/mapserver-6.0.1/mapimageio.c:738: undefined reference to `png_set_longjmp_fn'
collect2: ld returned 1 exit status
Here is my configure:
./configure --with-ogr=/usr/local/bin/gdal-config --with-gdal=/usr/local/bin/gda
l-config --with-wfs --with-wfsclient --with-wmsclient --enable-debug --with-curl
-config=/usr/bin/curl-config --with-proj=/usr --with-jpeg --with-freetype=/usr/b
in/ --with-postgis=/usr/bin/pg_config --with-mysql=/usr/bin/mysql_config --with-
libiconv=/usr --with-kml=yes --with-php=/usr/include/php5 --with-png=/usr/local
Since I have system libpng 1.2.27-2, I downloaded and installed 1.5.4 and put "--with-png=/usr/local" in my configure file. But seems like it doesn't help. I also tried with 1.4.8. Stiil the same issue. Also tried without "--with-png=/usr/local" (so it should use system libpng)...nothing
I have compiled using newest gdal 1.8.1. GDAL compiled ok with libpng 1.5.4.
Am I doing something wrong?
Thank you very much for any useful info
regards, dejan
