[mapserver-users] GetFeatureInfo using MySQL join - additional info
Dejan Gambin dejan.gambin at coin.hr
Tue Sep 13 03:00:33 EDT 2011
Some additional info:
Since I need this data only for GetFeatureRequest, it seems like I should use JOIN within a LAYER object. So I did the following:
LAYER
  DATA "my"
  DUMP TRUE
  TEMPLATE "template.html"
  HEADER "template_header.html"
  FOOTER "template_footer.html"
  JOIN
    NAME "test"
    CONNECTION "MySQL:gis,host=localhost,user=gis,password=gis,tables=katastar_vodnjan"
#    CONNECTION "PG:host=localhost user=postgres password=runda711 dbname=vodnjan port=5432"
    CONNECTIONTYPE ogr
    TABLE "katastar_vodnjan"
    FROM "KO_KC"
    TO "broj_ko_kc"
    TYPE ONE-TO-MANY
    TEMPLATE "template_join.html"
#	HEADER "template_header.html"
#	FOOTER "template_footer.html"
  END
I tried this with joined data from MySQL and from Postgres. No success. The interesting thing is, when I do:
shp2img -m my.map -o image.png -l "mylayer" -all_debug 3
I get:
[Tue Sep 13 08:58:04 2011].271467 msLoadMap(): 0.029s
[Tue Sep 13 08:58:04 2011].356888 msDrawMap(): Layer 0 (katastar_vodnjan_poligon), 0.083s
[Tue Sep 13 08:58:04 2011].356943 msDrawMap(): Drawing Label Cache, 0.000s
[Tue Sep 13 08:58:04 2011].356956 msDrawMap() total time: 0.085s
[Tue Sep 13 08:58:04 2011].399386 msSaveImage() total time: 0.042s
[Tue Sep 13 08:58:04 2011].402773 msPOSTGRESQLJoinClose() already close or never opened.
[Tue Sep 13 08:58:04 2011].402821 shp2img total time: 0.161s
Does anybody  know what is it? It happens for MySQL and Postgres database join
thanks very much
dejan
On 12. ruj. 2011., at 14:03, Dejan Gambin wrote:
> Hi,
> After solving my compile problem (thanks to thomas), I need to do GetFeatureInfo to a shape layer joined to MySQL table (non-spatial join).
> I compiled MapServer with MySQL support and everything seems ok, but "mapserv -v" doesn't return "INPUT=MYSQL". Is it supposed to anyway? Or it is enough to be compiled with gdal/ogr that supports MySQL?
> Because - when I do this:
> ogrinfo -sql "SELECT * FROM my LEFT JOIN 'MYSQL:gis,host=localhost,user=gis,password=gis'.katastar_vodnjan ON my.KO_KC=katastar_vodnjan.broj_ko_kc" /var/www/data/vodnjan/my.shp
> I get all the attributes from shape (dbf) and MySQL, so everything seems fine
> But using thi:
> LAYER # katastar vodnjan poligoni
>   NAME "mylayer"
>   STATUS ON
>   CONNECTIONTYPE ogr
>   CONNECTION "/var/www/data/vodnjan/my.shp"
>   DATA "SELECT * FROM my LEFT JOIN 'MYSQL:gis,host=localhost,user=gis,password=gis'.katastar_vodnjan ON my.KO_KC=katastar_vodnjan.broj_ko_kc"
>   TYPE POLYGON
> I don't get any information with GetFeatureInfo. The request is like:
> http://www.coin.hr/cgi-bin/mywms61?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&BBOX=5403800,4981350,5403980,4981460&SRS=EPSG:31275&WIDTH=400&HEIGHT=300&LAYERS=katastar_vodnjan_poligon&STYLES=&FORMAT=image/png&TRANSPARENT=true&QUERY_LAYERS=mylayer&INFO_FORMAT=gml&X=200&Y=100
> Using the same request with regular mapfile:
>   NAME "mylayer"
>   STATUS ON
>   DATA "my"
>   TYPE POLYGON
> returns one feature and its attributes from the dbf (tha is OK)
> I have also tried with JOIN clause in LAYER part, but this doesn't work either. Do I have to use owf? Am I doing something wrong?
> regards, dejan
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110913/b0d370e2/attachment.html
